ROAS Help
CthulhuSamurai
I am trying to create a ROAS in Packet Tracer and have come up to a wall.  In the attached file I can not ping the hosts of one VLAN to the other.  I can ping hosts on the same VLAN and the gateway.  I am really new at this and any help will be appreciated.
prefixlength
Hi :)
Using file you provided, I am able to ping every other host from any to any VLAN.
I would however change one thing. Remove the ip address of the physical gig0/0/0 interface.
interface GigabitEthernet0/0/0
    ip address 172.16.10.1 255.255.255.0
How many ping attempts did you allow, before determining that the pings are all failing?
prefixlength
Hi :)
It works fine for me too, today. Thank you for taking the time to look at it.
