rommon-mode issue
seegomaa
dears
i tried to copy IOS image in Rommon mode in 2620xm router the next message appeared :
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]: yes
PHY did not complete auto-negotation, status = 0x100
ARP: address resolution for 192.168.0.111 timed out.
ARP failed with failure code 1. TFTP transfer aborted.
TFTP: Operation terminated prematurely.
gschertz
A couple of questions for you. Where you connected directy to the router with a crossover cable, or where you going through a switch?
1. did you give the ethernet interface and ip address?
2. specify subnet mask?
3. specify a gateway? You would think that this one would not matter. But I have had rom uploads fail because of it.
4. the PHY did not complete auto-negotation appears to referr to ether an ip address from dhcp, or more likly the connection speed and duplex. If connecting through a switch, try a crossover cable instead. or hard code the ethernet port if you can in rom mode.
Gene
jarathbu
The ROMmon TFTP transfer works on the first LAN port only (tftpdnld). For more information review the following link:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
Hope this helps.
James
