rommon
gowdakssujan
What is the difference between 'boot' and 'reset' command in rommon mode????
Seb Rupik
Hi there,
The boot command on its own will attempt to load the first system image it finds in flash. You can suffix the boot command with an image name and it will attempt to load it.
The reset command is a akin to soft/ warm reload.
Issuing the boot command from rommon (assuming functioning system image is in place) would bring the system up quicker than a reset.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
