Beginner
Routable IPs behind Cisco 887VA
I have a block of eight routable IP addresses from my ISP.  I have a Cisco 887VA that I want to use as my router.  I know the router will take one of my IP addresses, but I'm having a problem getting the other IP addresses to route through the router.  My ADSL is up and running and I can ping addresses on the outside, but I have been unsuccessful at getting anything out from the inside.  Here is a copy of my running config:
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn XXXXXXXXXXX
controller VDSL 0
operating mode ansi
interface Ethernet0
no ip address
no fair-queue
interface ATM0
description DSL Interface
no ip address
no atm ilmi-keepalive
pvc 0/32
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
no ip address
interface Dialer1
ip address 71.xx.xx.102 255.255.255.248
ip mtu 1492
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxxxxxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxxxxx
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended inet
permit ip any any
line con 0
line aux 0
line vty 0 4
login
transport input all
end
I've tried to blow away the default VLAN (can't do that).  I have tried to create a bridge group, but that was unsuccessful.  Any help will be appreciated.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Beginner
Have you tried giving VLAN1 one of the IP addresses and then using ip unnumbered Vlan 1 on the dialer interface?
I've used this in the past for Cisco 877 routers with /29 blocks of IP addresses.
9 REPLIES 9
VIP Advisor
Re: Routable IPs behind Cisco 887VA
Hello Tom
Can you confirm if you using ADSL or VDSL
As I can see the ATM interface configured I am assuming its ADSL?
Can you explains a little bit more in what your issue is, Are you saying you Internal network isn't able to reach the internet?
Do you have private addressing for your internal LAN?
Res
paul
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
Beginner
I am running ADSL.
Issue:  I have four devices with public IP addresses.  Those four devices cannot get out to the internet.  Previously I had a DSL modem that would take one public IP address.  The other devices, I would point them to the DSL modem's public IP address as the default gateway and they would go out without issue.
Do I have private addressing?  I would like to have private addressing, but my primary concern is to get these four devices with public IPs out to the Internet.
Thank you.
Engager
hi tom,
just assign any one of the 8 routable IPs under VLAN 1 SVI and this will be your DG for the rest of the IP on that range.
assign other devices using the same IP subnet and connect on the available FE0-3 ports
Beginner
I did not try taking one of the eight IP addresses and assigning it to VLAN1.  I am reluctant to do that because my router will take two public IP addresses instead of one and that will leave me with no extra IP addresses to play with.  That's why I am trying to avoid using more IPs than I absolutely have to.  That why I tried doing the bridging.
Thank you for the suggestion.  I will give that a shot if there are no other options.
Beginner
Beginner
kmccourt, your suggestion worked perfectly.  Thank you for sharing.  I appreciate it.
Engager
Cool! Good info! +5
This works excellently! Thank
Thank you very much.
However, for some reason my EZVPN Client stopped working.
I've changed the outside VPN interface from Dailer0 to VLAN2 (dialer0 is my atm dialer which is now IP unnumbered, and VLAN2 is now my WAN VLAN). The tunnel comes back up but the client(this) router will not forward any traffic through the tunnel.
Am I missing something? There is rarely any change to the original configuration where dialer0 was designated as the vpn outside interface.
Here is my sanitized config of my 887VA:
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname XXX
boot-start-marker
boot-end-marker
no logging buffered
enable secret 4 XXX
no aaa new-model
memory-size iomem 10
clock timezone Paris 1 0
clock summer-time DST recurring last Sun Mar 2:00 last Sun Oct 3:00
crypto pki trustpoint TP-self-signed-129303053
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-129303053
 revocation-check none
 rsakeypair TP-self-signed-129303053
crypto pki certificate chain TP-self-signed-129303053
 certificate self-signed XX
        quit
no ip source-route
no ip bootp server
ip domain lookup source-interface Dialer0
ip domain name kpn.net
ip name-server 8.8.4.4
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZXXX
username XXX privilege 15 view root secret 4 XXX
controller VDSL 0
ip ssh version 2
crypto ipsec client ezvpn VPN
 connect auto
 group XXGroup key XXX
 local-address Vlan2
 mode network-extension
 peer XY.ZX.IJ.ZZ
 username XX password XX
 xauth userid mode local
interface Ethernet0
 no ip address
 shutdown
interface ATM0
 description KPN
 no ip address
 load-interval 30
 pvc 2/32
 no ip address
 no ip address
 no ip address
 switchport access vlan 2
 no ip address
interface Vlan1
 ip address 172.16.86.134 255.255.255.248
 no ip route-cache
 crypto ipsec client ezvpn VPN inside
interface Vlan2
 ip address <PUBLIC IP#1> 255.255.255.252
 ip virtual-reassembly in
 no ip route-cache
 no autostate (This statement was very important because the VPN needs to be online even though no physical devices were connected!)
interface Dialer0
 ip unnumbered Vlan2
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp chap hostname kpn
 ppp pap sent-username kpn password 7 05001601
 no cdp enable
no ip http server
ip http access-class 10
ip http authentication local
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 10 remark Access CCP/SSH
access-list 10 permit XXXX
dialer-list 1 protocol ip permit
no cdp run
line con 0
 no modem enable
line aux 0
line vty 0 4
 access-class 10 in
 privilege level 15
 login local
 transport input ssh
ntp update-calendar
ntp server nl.pool.ntp.org prefer source Dialer0
end
DOH!It was a bug in the 15.2
DOH!
It was a bug in the 15.2(4)M4 IOS software.
When I upgraded to 15.3(3)M4 and put the outside ezvpn interface back to dialer0 the problem was resolved!
(When I had vlan2 as the ezvpn outside interface the behaviour was the same as with the 15.2(4)M4 software. Tunnel up, but no tx from client side)
Content for Community-Ad
August's Community Spotlight Awards
