01-13-2013 12:26 AM - edited 03-04-2019 06:41 PM
Dear all,
Attached is the file of config where i am facing the routing loop issue when i do the bgp neighbor ship 'shut and no shut' on DCP router. my trace route to 1.1.1.1 (loopback address of BRANCH router) from the DCS router will get loop.
My Network requirement are as below:
1. I am running EIGRP between DCP and DCS router.
2. BGP routing protocol is running between CE to PE.
3. I have applied local preference on TCL1 router e.g. local preference 200 is set for DCP orignate network and 100 is for DCS orginate network,
4. attached diagram is made for active active mode.
kindly rectify the issue if i am doing any wrong thing...
Thanks in advance
Solved! Go to Solution.
01-13-2013 05:42 AM
Hello Hemant,
Well, it's Sunday and pushing people to solve your issue in two hours isn't going to speed up the process - this isn't TAC, this is a voluntary forum
Anyway, regarding your issue. This is what I believe is the sequence of steps causing the routing loop:
A correct solution would be to make a PE ignore routes received from a customer site that have been advertised to the site via the same or another PE. Ideally, this would be accomplished by tagging the routes at TCL1 when sending them to DCP and DCS and dropping the routes received from DCP and DCS if they carry the same tag. The problem is, however, that DCP and DCS perform BGP-and-EIGRP redistribution and the tag value may be lost in this redistribution, voiding this protection.
An alternative way of solving this is to use the BGP Site of Origin extended community attribute. Although originally created to prevent routing loops that occur for customer site-internal routes, it should help in this scenario as well:
How is this going to help us here? Well, assume that after the BGP peering between TCL1 and DCS comes up. DCS sends the 1.1.1.1 to TCL1, and TCL1 will mark it with a SoO attribute, say, SoO:64670:1. It will at first converge towards DCP, creating a temporary routing loop. However, as the 1.1.1.1 carries the SoO attribute of SoO:64670:1, it must not be advertised to DCS which carrier the same SoO attribute. Therefore, TCL1 shall withdraw the 1.1.1.1 from DCS. The 1.1.1.1 will thus be removed from DCS's routing table and will be removed from EIGRP as well. This in turn will cause the DCP to stop advertising the 1.1.1.1 in BGP back to TCL1, breaking the loop and allowing the TCL1 to reconverge on the correct path. Note that this solution is not perfect in that it potentially allows for a temporary routing loop to occur.
The configuration on TCL1 is very easy - simply add these commands:
router bgp 4755
address-family ipv4 vrf TATA-DBC
neighbor 10.80.80.2 soo 64670:1
neighbor 10.90.90.2 soo 64670:1
This should do the trick. Please note that as I explained earlier, the SoO is originally intended for a different purpose but it does prevent a route learned from a customer site to be readvertised to that site, which is a part of the routing loop problem you are facing.
If you want to read more about SoO attribute please visit these documents and discussions:
http://www.cisco.com/en/US/docs/ios/ios_xe/iproute_bgp/configuration/guide/irg_neighbor_soo_xe.html
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/L3VPNCon.html#wp359897
https://supportforums.cisco.com/message/3536081#3536081
https://supportforums.cisco.com/message/3740364#3740364
Best regards,
Peter
01-13-2013 02:03 AM
Please help me on this...
01-13-2013 05:42 AM
Hello Hemant,
router bgp 4755
Best regards,
Peter
01-13-2013 07:06 PM
Hello Peter,
I really appreciate your help on this. i have the some doubts and i will get in touch with you at the earliest. once again thanks on this.
01-13-2013 08:13 PM
Dear Peter,
below is the diagram where i have
mentioned the details, if i apply the site of
origin on my PE router than how my internal
network 192.168.7.0, 8.0 & 9.0 will communicate
with 192.168.10.0, 11.0 & 12. will they
communicate through internally eigrp or through
the BGP.
I have applied the prefix list to DR subnet as
shown below.
DRP:
192.168.10.0, 11.0 & 12.0 (Local preference 300)
and for rest of network the LP will only 50.
DRS
192.168.10.0, 11.0 & 12.0 (Local preference 250)
and for rest of network the LP will only 40.
Note: Branch will get the update the update of DR
network from the DR only so i have set the local
preference high to the DR subnet.
01-13-2013 10:42 PM
Hi Hemant,
I don't think there will be a loop for internal eigrp routes because of AD 90
01-14-2013 01:56 AM
Dear Peter/Pravin,
But my internal network 192.168.7.0, 8.0 & 9.0 will communicate
the BGP(MPLS).
01-14-2013 07:25 PM
my DC to DR point to point link also working on EIGRP.
01-14-2013 08:33 PM
Hi Hemant,
For DRP are you running BGP in dfferent AS.
You need to match the routes using access-list and change AD of the routes(192.168.7.0,8.0,9.0) if you want o commmunicate through eigrp.
Change according to your IP routing table.
Also SOO as peter told you to avoid loop.
Post traceroute output which can help
Praveen
01-14-2013 09:23 PM
Hi Hemant
Could you please paste output of traceroute to 1.1.1.1
need toknow which path it is getting looped
Praveen
01-14-2013 09:20 PM
Hello Pravin,
We have not done anything on our routers for orgnization, however our IPs are commnucating through EIGRPonly. we have only mentined configuration in the above snapshot. i dont know why is it happening? i am also trying to understande that only.
Note: our point to point link is being used for only DC DR communication. the synchronization of the servers will heppen throgh the EIGRP only.
Thanks.
Hemant
01-14-2013 10:24 PM
Dear Pravin,
my routing loop issue has been resolved as per the said statement of Mr. Peter. but the query is related to the my DC DR synchrinization which is happening through point to point link only which is on EIGRP and we are using differernt AS number for BGP. I wanted to just know that is there is there anything which is prefering EIGRP instead of BGP.
Note: I have not made DC DR connfiguration in LAB but it is happening in my orgination and configuration is same as mention above in the Diagram.
01-14-2013 10:46 PM
Hi Hemant,
check shutting down EIGR link and see routes is getting through BGp or not.
You need to check routes are recived through both BGP and EIGRP.
01-15-2013 07:13 PM
As per the SOO rules, the router will not re advertise to that one from where it is received and in the mentioned above diagram my network for 192.168.10.0 will be received on TCL1 from two ways. one from the DCP router and the second from the DRP. now you tell me which route will be dropped?? i am thinking, this is the the reasone where my internal eigrp is communicaing through the intarnal eigrp instead of EBGP.
01-16-2013 05:32 AM
Hello Hemant,
I apologize, I was out of this thread for several days and I see certain advances in your issue. I am confused, though, whether there is still something that needs to be corrected in your setup. Can you perhaps try to concisely summarize the points that still needs solution?
Best regards,
Peter
