Route map question
caijunjie
May i know wat doe sthe below command mean?
network A.A.A.A mask B.B.B.B route-map community-no-export
route-map community-no-export permit 10
set local-preference 100
set community 100:12345 no-export
access-list 10 access-list 10 permit 64.220.221.96 0.0.0.31
Does the above mean the below.
- Take ip that is permit by access list 10 and apply the route map and advertise it out?
Please help
Does the above mean
Danilo Dy
The answer is NO.
The route-map has a "set" parameters but no "match" parameter
However, since you have the line "network A.A.A.A mask B.B.B.B route-map community-no-export" this means the route-map "set" parameters applies to this network "A.A.A.A/B.B.B.B". When the router announce this prefix to its neighbor, it will have those attributes set in the route-map.
You can see it by checking what is being advertised to your peers. i.e.
show ip bgp neighbor peer_ip_address advertised-routes
regards,
Dandy
Thanks for the reply, u are right, i had get access list and route map mix up.
Alan
