route map question
bsudol79p
Hi, my question is can I have multiple actions in policy based routing statement. For example, I would like for the PBR first to NAT a subnet then send it to next hop. Here is my config.
route-map WS permit 10
match ip address 10
set ip next-hop x.x.x.x
access-list 10 permit ip 172.21.19.0 0.0.0.255 -- this would take the subnet traffic and send it to x.x.x.x
then if I have NAT statement
ip nat inside source route-map WS interface s 0 overload
Would this work? Or do I have to create 2 seperate PBRs that do each would do one task. I just would like to keep the config short and not complicated that is the reason I am asking. Also does the secquence of the statements make a difference? I think that routing is performed first before NATing if I am not mistaken. Thanks for your help.
shivlu jain
Level 5
Level 5
as per sequence of statements first nat will be performed then routing takes place.
regards
shivlu
