Route Map -- Why match this sequence?
pabburi01
Hi All,
Why 10.1.1.0/24 is match tag 1 and 20.1.1.0/24 is match tag 2 ??
C6509 and OS Version is 12.2(18)SXF7
#sh ip ro 10.1.1.0
Routing entry for 10.1.1.0/24
  Known via "static", distance 1, metric 0
  Tag 2
  Redistributing via bgp 1
  Advertised by bgp 1 route-map static-to-bgp
  Routing Descriptor Blocks:
  * 1.1.1.1, via GigabitEthernet2/31
      Route metric is 0, traffic share count is 1
      Route tag 1
    1.1.1.5, via GigabitEthernet2/30
      Route tag 2
#sh ip ro 20.1.1.0
Routing entry for 20.1.1.0/24
  Tag 1
  * 1.1.1.5, via GigabitEthernet2/30
      Route tag 1
      Route tag 2
Following is my configuration--------------------------------------------------------------------------------------
ip route 10.1.1.0 255.255.255.0 GigabitEthernet2/31 1.1.1.1 tag 1
ip route 10.1.1.0 255.255.255.0 GigabitEthernet2/30 1.1.1.5 tag 2
ip route 20.1.1.0 255.255.255.0 GigabitEthernet2/30 1.1.1.1 tag 1
ip route 20.1.1.0 255.255.255.0 GigabitEthernet2/31 1.1.1.5 tag 2
route-map static-to-bgp, permit, sequence 10
  Match clauses:
    tag 2
  Set clauses:
    metric 20
  Policy routing matches: 0 packets, 0 bytes
route-map static-to-bgp, permit, sequence 20
  Match clauses:
    tag 1
  Set clauses:
    metric 10
5 Replies 5
Jon Marshall
Can you post -
"sh ip bgp 10.1.1.0 255.255.255.0" and "sh ip bgp 20.1.1.0 255.255.255.0"
Jon
Hi Jon,
#sh ip bgp 10.1.1.0 255.255.255.0
BGP routing table entry for 10.1.1.0/24, version 25
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Multipath: eBGP
Flag: 0x880
  Advertised to update-groups:
  Local
    0.0.0.0 from 0.0.0.0 (100.1.1.1)
      Origin incomplete, metric 20, localpref 100, weight 32768, valid, sourced, best
#sh ip bgp 20.1.1.0 255.255.255.0
BGP routing table entry for 20.1.1.0/24, version 24
Multipath: eBGP
Flag: 0x880
  Local
      Origin incomplete, metric 10, localpref 100, weight 32768, valid, sourced, best
milan.kulik
Level 10
Level 10
I believe it's always the last static route entered for the same prefix which "wins" of you don't specify different ADs?
Try to enter
once more and observe what outout you'll get for
#sh ip ro 10.1.1.0
after that.
Best regards,
Milan
#sh run | i ip route
#sh ip ro 10.1.1.0
  Tag 2
  Redistributing via bgp 3786
  Advertised by bgp 3786 route-map static-to-bgp
      Route tag 2
      Route tag 1
I think.. Gi2/30 is faster than Gi2/31, so match tag 2(10.1.1.0) and tag 1(20.1.1.0)
Hello
You have set tags on your static routes then the route-map is matching on these tags and setting a metric value when advertised into bgp
Res
Paul
Kind Regards
Paul
