Route map with continue clause
verma-rohit
Level 2
Level 2
I was experimenting with route-map with continue clause, however the use of continue clause does not set well with my understanding of its processing.
1. A route matches a match statement execute its configured set values and then jumps to other sequence number as per configured continue statement.
2. If next route-map sequence has no match statement, it should execute configured set action.
1. Access and Core are OSPF neighbors.
2. On Core:
Core#show ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
192.168.0.6       1   FULL/DR         00:00:39    10.0.128.2      GigabitEthernet0/2
Core#show ip route ospf
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
      192.168.0.0/32 is subnetted, 3 subnets
O        192.168.0.6 [110/2] via 10.0.128.2, 00:39:07, GigabitEthernet0/2
O E2  192.168.1.0/24 [110/20] via 10.0.128.2, 00:39:07, GigabitEthernet0/2
      192.168.2.0/32 is subnetted, 1 subnets
O E2     192.168.2.1 [110/20] via 10.0.128.2, 00:39:07, GigabitEthernet0/2
Core#
Core#
3. On Same Core, I have BGP configured to perform OSPF route  redistribution:
OSPF route on Core with TAG 2001
Core#show ip route 192.168.2.1
Routing entry for 192.168.2.1/32
  Known via "ospf 64501", distance 110, metric 20
  Tag 2001, type extern 2, forward metric 1
  Redistributing via bgp 64501
  Advertised by bgp 64501 route-map OSPF2BGP
  Last update from 10.0.128.2 on GigabitEthernet0/2, 00:50:55 ago
  Routing Descriptor Blocks:
  * 10.0.128.2, from 192.168.0.6, 00:50:55 ago, via GigabitEthernet0/2
      Route metric is 20, traffic share count is 1
Route tag 2001 Core#sh run | s r b router bgp 64501 bgp router-id 192.168.0.5 bgp log-neighbor-changes neighbor 10.0.0.2 remote-as 65001 neighbor 10.0.0.2 description Client neighbor 10.0.0.5 remote-as 64500 neighbor 10.0.0.5 description eBGP to Upstream ! address-family ipv4 network 10.0.0.0 mask 255.255.0.0 network 192.168.0.5 mask 255.255.255.255 redistribute ospf 64501 route-map OSPF2BGP neighbor 10.0.0.2 activate neighbor 10.0.0.2 send-community neighbor 10.0.0.2 next-hop-self neighbor 10.0.0.2 route-map FromClient in neighbor 10.0.0.5 activate neighbor 10.0.0.5 send-community neighbor 10.0.0.5 next-hop-self exit-address-family Core#
4. Route-map on Core
Spoiler
Core#show route-map OSPF2BGP
route-map OSPF2BGP, permit, sequence 10
  Match clauses:
    route-type external
     tag 2000
  Continue: to next entry 11
  Set clauses:
    community 64501:2 additive
    origin egp 64501
  Policy routing matches: 0 packets, 0 bytes
route-map OSPF2BGP, permit, sequence 11
  Match clauses:
    route-type external
  Continue: to next entry 20
  Set clauses:
    community 64501:2001 additive
    origin igp
route-map OSPF2BGP, permit, sequence 20
  Match clauses:
  Set clauses:
    weight 200
Core#
Result:
On core, I anticipated BGP attributes for route 192.168.2.1 to have:
1. community 64501:2001 and origin as IGP
2. As there is continue configured on in seq 11, control moves to seq 20 and assign weight 200.
However , seq 20 is never executed it seems. Any reason why ?
Core#show ip bgp 192.168.2.1
BGP routing table entry for 192.168.2.1/32, version 8
Paths: (1 available, best #1, table default)
  Advertised to update-groups:
  Refresh Epoch 1
  Local
    10.0.128.2 from 0.0.0.0 (192.168.0.5)
      Origin IGP, metric 20, localpref 100, weight 32768, valid, sourced, best
      Community: 64501:2001
      rx pathid: 0, tx pathid: 0x0
Hello @verma-rohit ,
all the configuration examples in the shared link show route-maps applied to BGP neighbor statements for this use case the route-map continue command  has been introduced and supported.
The continue command is not supported in route-maps used for redistribution like in your tests and in the tests performed in the blog mentioned by Georg.
Hope to help
Giuseppe
18 Replies 18
verma-rohit
Level 2
Level 2
Please ignore spoiler tag
at first glance, I would say your match clauses in sequence 10 and 11 don't match, so 12 is never executed:
Match clauses:
route-type external
tag 2000
Set clauses:
origin egp 64501
Match clauses:
route-type external
Set clauses:
origin igp
Match clauses:
Set clauses:
weight 200
Core#
Add the same tag to sequence 11:
Match clauses:
route-type external
tag 2000
Set clauses:
origin egp 64501
Match clauses:
route-type external
--> tag 2000
Set clauses:
origin igp
Match clauses:
Set clauses:
weight 200
Core#
Thanks for your feedback.
Well seq 11 did match because the said route is an external ( E2 )  route and as a result community  64501:2001  and origin was set as IGP.
what if you match sequence 20 as well ? I think the logic is that the match statements have to be the same for each sequence if you use the 'continue' but everything else that does NOT match the previous will get the weight you configured.
Match clauses:
route-type external
tag 2000
Set clauses:
origin egp 64501
Match clauses:
route-type external
Set clauses:
origin igp
route-map OSPF2BGP, permit, sequence 20Match clauses:
--> route-type external
Set clauses:
weight 200
Core#
I did add match clause in seq 20, however  weight is still unchanged.
  Match clauses:
    route-type external
     tag 2000
  Set clauses:
    origin egp 64501
  Match clauses:
    route-type external
  Set clauses:
    origin igp
  Match clauses:
    route-type external
  Set clauses:
    weight 200
Core#
  Last update from 10.0.128.2 on GigabitEthernet0/2, 00:35:47 ago
  * 10.0.128.2, from 192.168.0.6, 00:35:47 ago, via GigabitEthernet0/2
      Route tag 2001
BGP routing table entry for 192.168.2.1/32, version 6
  Refresh Epoch 1
  Local
I'll try to lab this...can you post the full running configs of both the access and the core router ?
Files are attached , Shared below is the topology.
I'll lab this up...thanks for the files.
I ran into the same issue you had. For some reason, the 'continue' statement does not seem to work in route maps that are used in redistribution of routing protocols. The only way I got this to work is with the route map below (the 'additive' obviously is redundant). I did come across a document though that mirrors your setup. I am not sure if this is VIRL specific, and if the 'continue' clause works in e.g. XE.
Have a look at what this user noticed:
BGP Route Maps and Continue Feature Limitations
https://blog.ipspace.net/2016/05/bgp-route-maps-and-continue-feature.html
route-map OSPF2BGP permit 10
match tag 2000
match route-type external
set origin egp 64501
set community 64501:2 additive
route-map OSPF2BGP permit 11
set origin igp
set community 64501:2001 additive
set weight 200
I have gone through the shared link. From the website:
The lack of support for continue clause was somewhat expected after reading the relevant IOS documentation, and without the continue clause it makes no sense using set community additive in a redistribution point (where source routes have no BGP communities).
Link: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/configuration/15-mt/irg-15-mt-book/irg-route-map-continue.html
Where exactly in shared link author talsk about " lack of support for continue clause" ?
Hope to help
Giuseppe
Hello
I manage to test this last night and TBH it wasnt soemthing i was aware of, you would think it would be documented regards its restriction with redistribution or is this be something cisco will expect us to logically take into account
3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T14
7200 Software (C7200-ADVENTERPRISEK9-M), Version 15.2(4)M11, RELEASE SOFTWARE (fc2
IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.8(3)M2, RELEASE SOFTWARE (fc2
Cisco IOS Software [Fuji], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.1, RELEASE SOFTWARE (fc2)
% "TST" used as redistribute ospf into bgp route-map, continue match not supported
% not supported match will behave as route-map with no match
% "TST" used as redistribute ospf into bgp route-map, set community add not supported
Kind Regards
Paul
Hello @paul driver ,
your test results are exactly the same as those shown in the link
by Ivan Pepelnjack
this link was found by @Georg Pauwen  and reported in this thread. The source is rather reliable.
About the continue statement I remember it was introduced for BGP only.
There was another recent thread where the OP tried to use the continue in a route map used to redistribute into EIGRP wth no success.
In my humble opinion the OP of this thread is actually repeating the lab setup reported in that blog page with same results.
Hope to help
Giuseppe
@Giuseppe Larosa
I don’t doubt the source isn’t viable mate especially coming from the likes Ivan it’s just quite frustrating  isn’t documented and I wasn’t aware this OP was plagiarized from IVAN post.
Anyway all good I have learnt something this morning I didn’t know last night!
Kind Regards
Paul
