Route Null0 for backup transit Wan
cmichilsen
We have several location connected to each other with any to any wan uplinks. Our primary wan is routed with OSPF instances. When a OSPF router isn't reachable anymore our switches will use the default static routes. This all is working fine and when we have an error on our primary Wan it automatically falls back to the static routes. But the only thing i want to do is that our telephony enviroment is not routed over our backup wan uplink, because there is no Qos on our backup wan.
Our config is like this:
router ospf 1
router-id 10.11.22.1
log-adjacency-changes
passive-interface default
no passive-interface Vlan95
network 10.9.5.0 0.0.0.255 area 0
network 10.11.22.1 0.0.0.0 area 0
network 10.22.9.0 0.0.0.255 area 0
network 10.22.0.0 0.0.255.255 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 10.22.6.10 254
ip route 10.12.6.0 255.255.255.0 10.22.6.10
I want to route 10.12.64.0 255.255.255.0 to a black hole, but only when the static routes are active.
Is it possible to do this?
thank you.
6 Replies 6
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without  consideration and with the reader's understanding that there's no     implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind.  Usage of  this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
If 10.12.64.0 is in your dynamic routing, have your tried a floating static for it?
If 10.12.64.0 is not in your dynamic routing, perhaps PBR might do the trick.
First i tried to ip route 10.12.64.0 255.255.255.0 10.100.100.1 (fake ip). But when i did a trace to 10.12.64.4 it was still possible.
So i think the 0.0.0.0 0.0.0.0 10.22.6.10 has a higher priority or something.
Second thing what i want is that the packets will be dropped if our primary wan uplink is inaccessable.
Thanks in advance.
Disclaimer
Posting
For a floating static to work as desired, you would need the dynamic route to disappear from your routing table.  Not knowing what's in your route table, nor how you "faked" your IP, can't say whether what you done was done correctly.
cmichilsen
Is it possible to block traffic with ip access lists? I want to drop traffic (outgoing) on a 3560 from networks 10.15.4.0/24 and 10.15.5.0/24.
I configured this
access-list 1 deny 10.15.4.0 0.0.0.255
access-list 2 deny 10.15.5.0 0.0.0.255
But then i wanted to apply these accesslists on swi fa0/1 and in the config i only saw the last access-list. Is it possible to apply two access-list on one switchport?
I did a conf t and then int fa0/1
ip access-group 1 in
ip access-group 2 in
But this is only for incoming traffic i think?
Please advise.
greetings chris
Chris
You can only have one acl per interface per direction but it's not a problem ie.
access-list 1 deny 10.15.5.0 0.0.0.255
int fa0/1
Jon
Jon,
Sorry for the late reply.
Thank you for your answer.
Is this the way to leave traffic on the Local LAN.
10.15.4.0/24 are our voip telephones. If our primary WAN link is down we want to drop this traffic. SO i want to create a
access list on our cisco 3560 that is on the same LAN. I'm a little confused with inbound and outbound ACL's
