Route summary
ArnoldJSimpson
Some providers may advertise a specific route from within the summary route, along with this summary route. Why the provider may choose to advertise in this manner?
JimWicks
Routing will always prefer the longest prefix match, so fo example if an organization has a /24 prefix they want to make reachable over two peering links, then they would advertize that prefix to both peers, but they could also advertize a /25 covering the lower half of their address range only towards Peer-A if (for some made up reason) they wanted inbound traffic to that sub-set of their address-range to prefer that link to Peer-A................if the link to Peer-A failed then all traffic to the /24 range would use the remaining available link as it is still advertizing the full /24 range.
balaji.bandi
As per i know when you like to do Traffic Engineering over different Router, may require leaking some routes, so it can be done based on the TE.  The advertisement of a subset of more specific routes in addition to performing the summary. Leaking routes can be done at the process by explicitly stating the prefixes to suppress, or on a neighbor level by indicating which prefixes should not be suppressed.
BB
JimWicks
Generally for the reason, and example, @JimWicks describes.
I.e. for some reason, you want to route a subnet prefix of summarized prefix differently.
