06-11-2020 01:55 PM - edited 06-11-2020 02:20 PM
PE-2 ip vrf CustA rd 1256:12 route-target export 1256:16 route-target import 1256:16 router ospf 12 vrf CustA redistribute bgp 65100 subnets network 192.168.12.0 0.0.0.15 area 0 router bgp 65100 bgp log-neighbor-changes no bgp default ipv4-unicast neighbor 5.5.5.5 remote-as 65100 neighbor 5.5.5.5 update-source Loopback0 ! address-family ipv4 exit-address-family ! address-family vpnv4 neighbor 5.5.5.5 activate neighbor 5.5.5.5 send-community both exit-address-family ! address-family ipv4 vrf CustA redistribute ospf 12 exit-address-family PE5 ip vrf CustA rd 1256:56 route-target export 1256:16 route-target import 1256:16 router ospf 56 vrf CustA redistribute bgp 65100 subnets network 192.168.56.0 0.0.0.15 area 0 router bgp 65100 bgp log-neighbor-changes no bgp default ipv4-unicast neighbor 2.2.2.2 remote-as 65100 neighbor 2.2.2.2 update-source Loopback0 ! address-family ipv4 exit-address-family ! address-family vpnv4 neighbor 2.2.2.2 activate neighbor 2.2.2.2 send-community extended exit-address-family ! address-family ipv4 vrf CustA redistribute ospf 56 exit-address-family
PE-2#show ip route vrf CustA ospf | b Gate Gateway of last resort is not set 1.0.0.0/32 is subnetted, 1 subnets O 1.1.1.1 [110/11] via 192.168.12.1, 00:32:17, Ethernet0/0 11.0.0.0/32 is subnetted, 1 subnets O 11.11.11.11 [110/11] via 192.168.12.1, 00:32:17, Ethernet0/0
CE-6#show ip route ospf | b Gateway Gateway of last resort is not set 1.0.0.0/32 is subnetted, 1 subnets O E2 1.1.1.1 [110/11] via 192.168.56.5, 00:11:25, Ethernet0/0 192.168.12.0/28 is subnetted, 1 subnets O E2 192.168.12.0 [110/1] via 192.168.56.5, 00:11:25, Ethernet0/0
CE-6 is behind PE5, 1.1.1.1 and 192.168.12.0/28 are behind PE2.
These two routes go from CE1 to CE6 over MPLS, should they be IA or E2 ?
The above is from my lab, but the video I am watching showing IA.
thanks !!
06-11-2020 02:08 PM
it should be IA routes since they belong to same Customer.
High level - Why you have different OSPF processes running? Do you run the same OSPF process on both the side - correct and test
06-11-2020 02:49 PM - edited 06-11-2020 02:54 PM
fixed.
thanks a lot !!!!
06-11-2020 02:53 PM
thanks, it fixed.
06-12-2020 12:19 AM
Glad that all working as expected.
06-12-2020 07:16 AM
I found I missed the following points:
06-14-2020 11:14 AM
if you like to have different OSPF processes - you can also use domain option on the PE side, so they will be announced the same LSA.
use case like if 2 companies merge and like to keep the existing config on the PE side.
06-14-2020 12:20 PM
