Route with gateway 0.0.0.0
Christian Jorge
Good morning
Checking an ACI leaf switch I found these static routes
ip route 10.10.0.0/16 0.0.0.0 200     (gateway 0.0.0.0 ?)
ip route 10.10.0.0/16 10.1.0.1 210
Checking the routing table, it's been considered only the route number 2 (distance 210)
10.10.0.0/16, ubest/mbest: 1/0
*via 10.1.0.1, vlan10, [210/0], 32w05d, static
I don't know (or have history about) why someone has created these routes, but I'm wondering:
- what the reason that a switch disregard the primary route (distance 200)?
- how a switch/router understands a static route with gateway 0.0.0.0?
- route with gateway 0.0.0.0 would be different than a route with a gateway Null0?
*ps: I have already seen before a route with gateway 0.0.0.0 only in BGP routing tables
Giuseppe Larosa
Hello @Christian Jorge ,
A static route with next-hop 0.0.0.0 is probably treated as invalid with a not specified next-hop.
This would explain why the second static route with AD 210 is installed because it has a valid IP next-hop hopefully pointing to another device.
A BGP next-hop of 0.0.0.0 applies to locally generated BGP prefixes.
Finally a static route to null0 is a valid static route that silently discards packets. null0 is a defined logical interface the waste bin an IP next-hop of 0.0.0.0 is not equivalent to it, it should just be treated as an undefined IP nv4 next-hop.
Hope to help
Giuseppe
Giuseppe Larosa
Hope to help
Giuseppe
Hello Giuseppe
Thanks for your answer.
I found something about this matter in Internet, even in another topic in Cisco Community:
https://community.cisco.com/t5/switching/static-route-next-hop-0-0-0-0-quot-ip-route-192-168-1-0-255-255/td-p/663840
but I think your explanation is clearer, makes sense and é exactly what I'd like to confirm
sorry can you more elaborate where exact you see next-hop 0.0.0.0 for static route in ACI ?
Actually I can see next-hop 0.0.0.0 only in static route configuration:
but exactly as explained before, this route/gateway is considered invalid and not input in routing table
