Join Customer Connection to register!
483
ANUJ BUTAIL
Beginner
RouteMap and NAT on the same interface Order of Precedence
I have the following configuration
I have configured PBR on the LAN interface stating that any traffic with this source should go through the tunnel interface also I want that that source to be Natted.
For example the internal host is 192.168.0.1 I want it to be NATTED to 202.12.12.12  and than 202.12.12.12 should be PBR through a Tunnel Interface on the WAN Interface.
My question is what will take precedence is it the NAT or the Route Maps?
Anuj
2 REPLIES 2
Milos Megis
Participant
Maybe this helps:
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/6209-5.html#topic1
Seb Rupik
VIP Advisor
Hi there,
Policy routing occurs on ingress to the router interface. NAT inside-to-outside occurs on egress.
Take a look at this document:
cheers,
Seb.
