10-14-2010 08:10 AM - edited 03-04-2019 10:07 AM
Cann't login to the router second time accessing the device
10-14-2010 08:32 AM
Unfortunately, your problem description does not help us in determining what is happening and how best we can help you. Can you describe exactly what is happening when you try to log in? Are you logging in via the console? Do you get a username/password prompt? Did you change the default username/password the 1st time you logged in?
Tim
10-14-2010 10:04 AM
New install nm it3 e3 card need config or point me in the direction to get info.
Mark J
10-14-2010 03:49 PM
Still not enough info.
What happens when you console into the appliance? Be more specific.
Your question is like going to Wal-Mart and asking the question "I've got US$35, what can I get?"
