Hi Eagleman.
I think, here is the problem. You are only using 5Mb out of 128Mb. So it seems as you have installed unsupported memory.
One thing you can do before replacing the memory is to load an older version of IOS like 12.3 or 12.2 to make sure the issue is not software related.
If that does not help, then you may want to replace the memory. All the parity errors in your attachment indicate memory issues.
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 5Mb.
Using 3 percent iomem. [5Mb/128Mb]
