取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
Router 4331 and SW SG300 - Mulitple vlans with trunk mode do not work
Mina Tawfik
I have the following setup:
Router 4331:
G0/0/0 - internet connection
G0/0/1 - Internal network.
     g0/0/1.10 - vlan 10.
ZBF is configured to internal zone (internal network), external zone (internet connection).
SW SG300
Gi1 - mode access - vlan10
Gi3 - mode access - vlan 30
Gi4 - mode access - vlan 40
Gi5 - mode access - vlan 50
Gi26 - mode trunk - vlan all
Computer connected to SW gi1 - network card on the laptop configured to dhcp on.
The initial setup is that configured the router with only vlan10 and site-to-site vpn tunnel.
Everything is working fine. Computer is getting an IP from vlan10. Connected to the internet and vpn tunnel without any issues.
When I created on the router:
g0/0/1.30 and g0/0/1.40 and g0/0/1.50 for vlan 30,40,50
The computer does not get an ip when connected to Sw gi1 or gi3 or gi4 or gi5.
Nothing works.
The setup I want is that:
Create multiple vlans on the router. 10,30,40,50
Trunk mode for the connection between the router and sw.
on the sw vlan10 goes to gi1
                vlan30 goes to gi3
                vlan40 goes to gi4
                vlan50 goes to gi5
                all vlan goes to gi26
I cannot get it to work for some reason that I could not find out why.
Here is Router Config file - working with vlan10 only created:
no platform punt-keepalive disable-kernel-core
hostname ci_secondary
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 -----
no aaa new-model
crypto key generate rsa general-keys modulus 2048
ip name-server ----- ----- -----
ip domain name ci.local
ip dhcp pool vlan10
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
dns-server -----
subscriber templating
vpdn enable
vpdn-group 1
vpdn-group pppoe
username mina privilege 15 password 0 -----
username dominic privilege 0 secret 5 -----
redundancy
mode none
vlan internal allocation policy ascending
class-map type inspect match-any priv-internet-class
match protocol http
match protocol https
match protocol dns
match protocol icmp
match protocol ssh
class-map type inspect match-any DHCP-ALLOW
match protocol udp
match access-group name ALLOW-DHCP
policy-map type inspect priv-internet-policy
class type inspect priv-internet-class
inspect
class type inspect DHCP-ALLOW
pass
class class-default
drop
zone security private
zone security internet
zone-pair security priv-internet-zone source private destination internet
service-policy type inspect priv-internet-policy
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
lifetime 28800
crypto isakmp key ----- address -----
crypto isakmp keepalive 180 periodic
crypto ipsec transform-set TS esp-3des esp-md5-hmac
mode tunnel
crypto map CMAP 70 ipsec-isakmp
set peer -----
set transform-set TS
match address DOM-VPN-TRAFFIC
crypto map CMAP 71 ipsec-isakmp
set peer -----
match address VPN-VDC
interface GigabitEthernet0/0/0
description Internet SecondaryWAN
ip address ----- -----
ip nat outside
zone-member security internet
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 1
crypto map CMAP
no shutdown
interface GigabitEthernet0/0/1
description SecondaryLAN
no ip address
ip nat inside
zone-member security private
negotiation auto
no shutdown
interface GigabitEthernet0/0/1.10
description vlan10
encapsulation dot1Q 10
ip address 10.10.20.1 255.255.255.0
ip nat inside
no shutdown
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
ip nat inside source route-map NONAT interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip dns server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 103.245.219.176
ip ssh version 2
ip access-list extended ALLOW-DHCP
permit udp any any eq bootps
permit udp any any eq bootpc
ip access-list extended DOM-VPN-TRAFFIC
permit ip 10.10.20.0 0.0.0.255 192.168.70.0 0.0.0.255
permit ip 10.10.20.0 0.0.0.255 192.168.71.0 0.0.0.255
ip access-list extended VPN-VDC
permit ip 10.10.20.0 0.0.0.255 192.168.27.0 0.0.0.255
access-list 1 permit 10.10.20.0 0.0.0.255
access-list 100 permit ip 10.10.20.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map SWITCHVOX permit 10
match ip address 110
route-map NONAT deny 10
match ip address DOM-VPN-TRAFFIC VPN-VDC
route-map NONAT permit 20
match ip address 1
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 1 in
exec-timeout 60 0
login local
transport input ssh
line vty 5 15
access-class 1 in
login local
end
Here is the SW config file:
vlan database
int vlan 10
name Internal-Staff-Network
int vlan 30
name Guest
int vlan 40
name R&D
int vlan 50
name Video-Conference
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname CI-HQ-ALS1
line ssh
exec-timeout 0
exit
username cisco password ----- privilege 15
interface gigabitethernet1
switchport mode access
switchport access vlan 10
interface gigabitethernet2
shutdown
interface gigabitethernet3
switchport access vlan 30
interface gigabitethernet4
switchport access vlan 40
interface gigabitethernet5
switchport access vlan 50
interface gigabitethernet6
shutdown
interface gigabitethernet7
shutdown
interface gigabitethernet8
shutdown
interface gigabitethernet9
shutdown
interface gigabitethernet10
shutdown
interface gigabitethernet11
shutdown
interface gigabitethernet12
shutdown
interface gigabitethernet13
shutdown
interface gigabitethernet14
shutdown
interface gigabitethernet15
shutdown
interface gigabitethernet16
shutdown
interface gigabitethernet17
shutdown
interface gigabitethernet18
shutdown
interface gigabitethernet19
shutdown
interface gigabitethernet20
shutdown
interface gigabitethernet21
shutdown
interface gigabitethernet22
shutdown
interface gigabitethernet23
shutdown
interface gigabitethernet24
shutdown
interface gigabitethernet25
shutdown
interface gigabitethernet26
switchport trunk allowed vlan add all
exit
These are the working setup. NO issues with that.
Now, when I change the router config file to the following:
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip dhcp pool vlan10
dns-server -----
ip dhcp pool vlan30
network 10.10.30.0 255.255.255.0
default-router 10.10.30.1
dns-server -----
ip dhcp pool vlan40
network 10.10.40.0 255.255.255.0
default-router 10.10.40.1
dns-server -----
ip dhcp pool vlan50
network 10.10.50.0 255.255.255.0
default-router 10.10.50.1
dns-server -----
vpdn enable
vpdn-group 1
vpdn-group pppoe
redundancy
mode none
match protocol http
match protocol dns
match protocol icmp
match protocol ssh
match protocol udp
inspect
pass
class class-default
drop
encr 3des
hash md5
group 2
lifetime 28800
mode tunnel
set peer -----
set peer -----
ip nat outside
negotiation auto
crypto map CMAP
no shutdown
description vlan10 internal network
no ip address
ip nat inside
negotiation auto
no shutdown
description vlan10
ip nat inside
no shutdown
interface GigabitEthernet0/0/1.30
description Guest Network
encapsulation dot1Q 30
ip address 10.10.30.1 255.255.255.0
ip nat inside
no shutdown
interface GigabitEthernet0/0/1.40
description R&D Network
encapsulation dot1Q 40
ip address 10.10.40.1 255.255.255.0
ip nat inside
no shutdown
interface GigabitEthernet0/0/1.50
description Video Conference Network
encapsulation dot1Q 50
ip address 10.10.50.1 255.255.255.0
ip nat inside
no shutdown
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
no ip http server
ip dns server
ip ssh version 2
match ip address 1
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 1 in
exec-timeout 60 0
login local
transport input ssh
line vty 5 15
access-class 1 in
login local
end
NOthing works at all.
Can anyone help with the issue as I cannot find a reason?
0 条回复0
