Highlighted
Beginner
Router BGP load sharing between direct E1 lease line and IPBGP
Dear Colleagues
I have CPE connected with E1 interface 2Mbps lease line, and we run eBGP accross
which is redundant by ISP internet connecting GRE Tunnel.
all connectivities are UP and running,
I have atttached configuration log and diagram for description
The priority BGP route is always with E1 interface,
My requirement is to make GRE tunnel as first priority or available both route for BGP destination
Can you please guide how to do that?
Router 1#
interface Serial0/0/0:0
ip address 216.200.72.21 255.255.255.252
interface Tunnel0
description GRE tunnel to Aicent GRX
ip address 64.125.140.173 255.255.255.252
ip mtu 1500
tunnel source 185.16.71.251
tunnel destination 79.132.225.178
crypto map macvpnmap
interface FastEthernet0/1.2
description GRX_IPVPN_SW_6509_1/39
encapsulation dot1Q 555
ip address 185.16.71.251 255.255.255.248
ip access-group ACL_IN in
no snmp trap link-status
router bgp 64906
synchronization
bgp log-neighbor-changes
network 64.125.140.172 mask 255.255.255.252
network 125.19.25.0 mask 255.255.255.192
network 216.200.72.20 mask 255.255.255.252
neighbor 64.125.140.174 remote-as 19440
neighbor 64.125.140.174 soft-reconfiguration inbound
neighbor 216.200.72.22 remote-as 19440
neighbor 216.200.72.22 description To-GRX-Aicent
neighbor 216.200.72.22 update-source Serial0/0/0:0
neighbor 216.200.72.22 version 4
neighbor 216.200.72.22 soft-reconfiguration inbound
no auto-summary
Router1#sh ip bgp summary
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
64.125.140.174  4 19440   99371  122943  1176630    0    0 3w2d         4457
216.200.72.22   4 19440 2160847 1564058  1176630    0    0 02:07:08     4457
Router1#sh ip route bgp
     187.191.0.0/16 is variably subnetted, 2 subnets, 2 masks
B       187.191.5.128/25 [20/0] via 216.200.72.22, 02:07:54
B       187.191.17.224/28 [20/0] via 216.200.72.22, 02:07:54
     193.56.242.0/28 is subnetted, 1 subnets
B       193.56.242.128 [20/0] via 216.200.72.22, 02:07:54
8 REPLIES 8
Highlighted
Hi Abhishek,
If you already see both paths in the "show ip bgp" output, it should be as easy as adding "maximum-paths 2" to your bgp configuration. This should provide per session load sharing.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Highlighted
Beginner
Sep 26, 2013 4:55 PM                             (in response to Harold Ritter)
! ***Match all routes via prefix list***
ip prefix-list PRIORITY seq 5 permit 0.0.0.0/0 le 32
! ***Increase weight with route-map***
route-map PREFER-IT
match ip address prefix-list PRIORITY
set weight 1000
! ***Apply route-map to neighbor inbound***
neighbor 64.125.140.174 route-map PREFER-IT in
end
Apply this config and then soft clear the neighbor 65.125.140.174
It  will increase the weight of the routes learnt from the BGP peer across  GRE and hence your router will prefer the GRE tunnel as primary link.
Highlighted
Hi Vishesh
I have done this, and my IP GRE route has started picking some traffic, but not all,
so I would say roughly 70% of the traffic is still going via Serial 0/0/0:0
and rest 30% is via GRE tunnel.
I have clear the GRE cache
I am expecting Serial 0/0/0:0 will be back up route,
Do you need more logs,
I am keeping this configuration for longer time
*  192.68.138.128/29
                    216.200.72.22                          0 19440 35030 64792 i
*                   64.125.140.174                      1000 19440 19440 19440 35030 64792 i
*  192.68.138.128/25
*  192.68.138.136/29
*  192.68.138.144/30
thanks
Highlighted
Beginner
Did you soft clear the neighbor?
Please attach a .txt file with the output of
show ip bgp summary
show ip bgp
show ip route
Highlighted
hi
pl find the logs, thanks for suggestion
Highlighted
Beginner
Route preference changes in BGP takes effect only after clearing the BGP neighborship. Mostly soft clear does the job; however sometimes we may need to hard reset the neighbor as well.
It is working as the routes learned from the BGP peer 64.125.140.174 are preffered because of the higher weight and installed in routing table.
*   217.164.95.8/29  216.200.72.22                         0      19440 8959 64673 i
*>                           64.125.140.174                      1000  19440 19440 19440 8959 64673 i
B       217.164.95.8/29 [20/0] via 64.125.140.174, 00:02:22
GOOD JOB !!!
Highlighted
Hello Vishesh
I have re-established neighbour relationship, by hard reset the interface itself,
but still traffic is going via that route
64.125.140.174  4 19440  119819  150152     4539    0    0 00:10:49     4494
216.200.72.22   4 19440 2201042 1602590     4539    0    0 00:03:18     4494
Airtel_GRX#
sh ip bgp and sh ip route are attached
please advice
thanks for all your assistance
Highlighted
Routing table says that next-hop is 64.125.140.174 which is across the tunnel. But you say traffic goes out 216.200.72.22; Is there any PBR that is routing the traffic out Serial0/0/0:0?
Please check the output of -
show ip cef 64.125.140.174
show ip cef exact-route 64.125.140.173  64.125.140.174
show ip cef exact-route source-IP destination-IP     <<<< To check how traffic will be switched by the router coming from source-IP and going to destination-IP
Also please post the complete show run. Also please tell me how are you checking that the traffic is going out the serial interface and not tunnel.
