Router C1101 Cellular interface down
I'm working with a C1101-4PLTEP router and trying to bring the Cellular interface UP, but there are some issues.
The SIM cards are working on a mobile phone. On the router, they were removed and inserted again.
Some logs I've been running into
*Dec 22 11:32:47.101 GMT-2: Cellular0/2/0 Modem Attached First Time: 0, Tech Mode: 0, Modem Mode: 0, curr_dl_bytes : 0
*Dec 22 11:32:47.101 GMT-2: Cellular0/2/0 RSSI : 128, PS State: 0, EMM REG State: 0, is_downlink_rx: 0
*Dec 22 11:32:47.101 GMT-2: MSD: Modem is NOT yet attached in LTE mode
Dec 22 15:33:34.928 GMT-2: DDR: Dialer Watch: Dial Reason: Secondary of group 1 AVAILABLE
*Dec 22 15:33:34.928 GMT-2: DDR: Dialer Watch: watch-group = 1,
*Dec 22 15:33:34.928 GMT-2: DDR: dialing secondary by dialer string lte on Ce0/2/0
*Dec 22 15:33:34.928 GMT-2: DDR: Dialer Watch: Stale dialer watch group 1 found on Ce0/2/0
*Dec 22 15:33:34.928 GMT-2: Ce0/2/0 DDR: Attempting to dial lteCellular0/2/0: Data connection setup failed sincemodem (PS=2,EMM=0) unattached
*Dec 22 15:33:34.928 GMT-2: Ce0/2/0 DDR: Unable to dial lte.
*Dec 22 15:33:34.928 GMT-2: Ce0/2/0 DDR: Dialer Watch: resetting call in progress
Has anyone run into a similar issue?
9 Replies 9
share the config if you can
MHM
Hello, I attached the router config.
balaji.bandi
Where did you get this configure from ?
Are you looking your cellular to in VRF  and you want to VPN ?
First i would suggest make sure your cellular working before you do any further configuration.
#cellular 0/2/0 lte profile create 1 provider.com
interface Cellular0/2/0
description CONEXAO 3G/4G VIVO
bandwidth 512
ip nat outside
ip address negotiated
no ip unreachables
dialer in-band
dialer idle-timeout 300
dialer watch-group 1
dialer-group 1
pulse-time 1
ip virtual-reassembly
interface GigabitEthernet0/0/0 ip address 192.168.1.1 255.255.255.0 ip nat inside
ip nat inside source list 1 interface Cellular0/2/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/2/0
access-list 1 permit any
dialer-list 1 protocol ip permit
checks
#show cellular 0/2/0 radio
#show cellular 0/2/0 connection
#show interfaces cellular 0/2/0
#show ip interface brief
 For reference some document :
https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-7/cisco_1100_series_swcfg_xe_16_7_x/cisco_1100_series_swcfg_chapter_01011.html
BB
Hello @KarolineSoares76078 ,
I believe you are missing some commands from your config:
1. Can you change the modem chat script to allow a greater timeout:
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
2. Add the following to your cellular interface:
encapsulation slip
dialer string lte
async mode interactive
3. On the line associated with the cellular modem - I assume it's line 0/2/0 but you should check - you should have the following:
line 0/2/0
script dialer lte
modem InOut
no exec
Regards, LG
*** Please Rate All Helpful Responses ***
Thank you for the response.
I changed timeout to 60, but the commands under interface Cellular0/2/0 are not accepted.
can you show the output of:
show cellular 0/2/0 profile
--> The SIM cards are working on a mobile phone. On the router, they were removed and inserted again.
Does that mean your SIM card worked before in a router ? Who is your provider ?
Attached is the output for the show cellular commands.
*Feb 2 11:26:38.047 GMT-2: %CELLWAN-2-SIM_NOT_PRESENT: [Cellular0/2/0]: SIM is not present in Slot 1
Do you have SIM installed ?
who is the provider ?
Modem Security Information
Active SIM = 1
SIM switchover attempts = 1
Card Holder Verification (CHV1) = Disabled
SIM Status = Not inserted
SIM User Operation Required = None
Number of CHV1 Retries remaining = 0
check some example working one in this BLOG :
https://wannabelab.blogspot.com/2020/01/configuring-cisco-1100-lte-advanced.html
BB
Yes, the SIM cards are installed.
We're in Brazil, so first one provider is Vivo, and second one is TIM.
The router doesn't accept this commands under interface Cellular:
lte modem link-recovery rssi onset-threshold -110
 lte modem link-recovery monitor-timer 20
 lte modem link-recovery wait-timer 10
