Router Capabilities
desheehan
Is it just me or is Cisco.com a bit rough to navigate?
I'm looking for specifications/capabilities for specific routers/switches.
For example.....where would I go to find the maximum throughput rate of a 2811 or 3845?
I've only found partial information in various locations of Cisco.com.
I'm sure there is a place on the site that has all this viewable by model and class.
Thanks!
nethelper
Level 3
Level 3
check the link below, this might be what you are looking for:
Portable Product Sheet - Router Performance
http://www.cisco.com/warp/public/765/tools/quickreference/routerperformance.pdf
By the way, CCO can indeed be hard to navigate, due to the sheer amount of information available. I think there are something like 2 million pages...:)
Nethelper
nethelper
Level 3
Level 3
Nethelper
BRILLIANT!!
This is exactly what I was looking for.
Thanks!
