Highlighted
Beginner
Router enters in ROMMON mode
Our network is down, because of the problem in flash card. The router enters in ROMMON mode after restarting. Could anyone tell me the command to boot the router using the IOS stored in TFTP server. We are using 1841 router.
Everyone's tags (4)
3 REPLIES 3
Highlighted
use tftpdnld
Here s the link for reference
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon.html#wp1070700
use tftpdnld -r option if the flash is not usable
Highlighted
Beginner
HI Sabari,
Do u want to copy IOS from tftp server  ? if yes then please follow the below given steps:-
rommon1 > IP_ADDRESS=
rommon 2> IP_SUBNET_MASK=
rommon 3> DEFAULT_GATEWAY=
rommon 4> TFTP_SERVER=
rommon 5> TFTP_FILE=  < address of the tftpfile i.e.IOS>
rommon 6> tftpdnld
then yes when it cisco reconfirms to check that you are sure
MJ
Highlighted
Beginner
Hi Sabri,
If problem is in your flash card then check with you internal TAC team.
MJ
