Router for full BGP table
amrishp2300
Hi Experts,
I am looking for a Cisco router for dual homing to ISPs. I will connect to two different ISPs and recieve full BGP table from them. I am comparing 3900/7200 series routers, what model would be ideal for this requirement.
I am looking for an economical solution. Please help.
AP
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Okay then, Cisco recommends a 3925 for up to 100 Mbps of WAN bandwidth, and a 3945 for up to 150 Mbps.  Cisco's recommendations are usually conservative.
5 Replies 5
Dragan Ilic
Level 4
Level 4
If you can - go with ASR series of routers.
If not - 3900 is fine as long as you have minimum of 1GB RAM memory...better 3945 if it's OK.
HTH,
Dragan
HTH,
Dragan
Joseph W. Doherty
Disclaimer
Posting
Principle determinate, for a router, is volume of expected transit traffic.
For Internet BGP, you need sufficient RAM and you'll need to allow for some CPU for managing Internet route table(s).
As you didn't indicate the capacity of your expected ISP links, cannot recommend what "size" router might be suitable.
BTW, 7200s are EoL.  The 4451-X is about equivalent to a NPE-G1/G2 (depending on performance license) and the ASR1K performance starts at about NSE-1.
ISP links would be 50Mbps each. Thanks for your reply.
Disclaimer
Posting
Thank you Joseph and Dragan for your suggestions.
Have a great day!
