Router Hangup
vicky.dhas
Dear All,
Please help with this issue am facing with the network.
Network diagram is attached.
We are taking hosted contact center service from service provider.Connectivit is over MPLS.Cisco 881 is the CPE router.We are using our own LAN ip pool with default gateway to L3 switch interface IP.
LAN IP pool is 10.93.203.0/24 which is nated with service providers IP block 172.17.241.0/25 in the CPE router(becasue SP allows only this block to talk to their platform). Between CPE 881 and L3 switch we have configured first 2 IPs for service provider block.Detailed config is given below.
We are facing problem as router is hanging up interminttently in 3-4 days,if we reboot or clear the cache , service is back and running.Please help iwth your suggestions.
Pelase find below show arp
Router#sh arp
Protocol  Address            Age (min)  Hardware Addr   Type   Interface
Internet  10.75.123.37           14   001e.f741.b580  ARPA   FastEthernet4
Internet  10.75.123.38            -   4c4e.354d.c00c  ARPA   FastEthernet4
Internet  172.17.241.1            -   4c4e.354d.c008  ARPA   Vlan1
Internet  172.17.241.4            -   4c4e.354d.c008  ARPA   Vlan1
Internet  172.17.241.8            -   4c4e.354d.c008  ARPA   Vlan1
Internet  172.17.241.9            -   4c4e.354d.c008  ARPA   Vlan1
Internet  172.17.241.10           -   4c4e.354d.c008  ARPA   Vlan1
Internet  172.17.241.11           -   4c4e.354d.c008  ARPA   Vlan1
Internet  172.17.241.12           -   4c4e.354d.c008  ARPA   Vlan1
Internet  172.17.241.13           -   4c4e.354d.c008  ARPA   Vlan1
Internet  172.17.241.14           -   4c4e.354d.c008  ARPA   Vlan1
CPE 881 configuration
Router#sh run
interface Loopback0
description ****MANAGEMENT LOOPBACK****
ip address 10.72.156.150 255.255.255.255
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description ****WAN LINK****
ip address 10.75.123.38 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
interface Vlan1
description ****LAN LINK****
ip address 172.17.241.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool <Customer> 172.17.241.1 172.17.241.254 netmask 255.255.255.0 add-route
ip nat inside source list 20 pool <Customer>
ip route 0.0.0.0 0.0.0.0 FastEthernet4 10.75.123.37
ip route 10.93.203.0 255.255.255.0 172.17.241.11
logging trap debugging
logging facility local5
logging source-interface FastEthernet4
logging 10.70.0.201
logging 10.209.19.200
access-list 10 permit 203.200.231.222
access-list 10 permit 10.70.0.202
access-list 10 permit 172.31.6.123
access-list 10 permit 202.54.29.25
access-list 10 permit 10.209.19.0 0.0.0.255
access-list 10 deny   any
access-list 20 permit 10.93.203.0 0.0.0.255
no cdp run
Vicky
paolo bevilacqua
Update IOS and check again.
Thanks Paolo, Before than i want to make sure that there is no issue with config part
Vinay
anyone got any other view?
