ROUTER IS NOT SAVING THE CONFIGS
tabish bhat
Beginner
Beginner
Hi All
when i try to saving down configs on router it gives the following mesg ..
R1(config)#wr
Attempting to overwrite an NVRAM configuration previously written
by a different version of the system image.
Overwrite the previous NVRAM configuration?[confirm]
Invalid Pointer value(4589AE30) in private configuration structure
*Sep 12 08:55:30.839: NV: Invalid Pointer value(4589AE30) in private configuration structure
Any idea...
Tash Bhat
2 Accepted Solutions
garapoglou
Participant
Participant
Did you perform an IOS upgrade before the error message?
Best regards
Giorgos
Dear Tabish,
Please do following steps.
1. Save old config template
2. erase startup-config
3. wr erase
4. reload
5. when ask would you like to initial config ?? N
6. paste Old config again
Sure then u will able to save without any errors
7 Replies 7
garapoglou
Participant
Participant
Best regards
Giorgos
Hi Giorgos
no i have not upgraded IOS yet
Hi Tash,
Check which IOS version you currently have by using the "sh flash:" command.
Then go to the global configuration mode using the "conf t" command and type
boot system flash:
Where is the IOS version in the flash memory of the device.
Best regards,
Giorgos
Hi Giorgos,
still it is showing the same mesg
Tash Bhat
Could you run the "sh ver" command and tell me what's your current configuration-register?
Thanks in advance,
Giorgos
Dear Tabish,
3. wr erase
4. reload
THANKS A TON
HTH !!!
it is working fine now!!
Recognize Your Peers
