Router Memory Issue
lovefunlove
Dear Friends,
I have a cisco 2651-XM Router.I was reseting the password and gave wrong confreg value by mistake.Later on i retrived the password by writting the correct confreg value.
Now when after doing the configuration, writing it on memmory by Write Mem, and reloading , all the configuration get vanished.
I have tried this couple of time but every time my router asked for new configuration.I am getiing the following error after the post.
Mar 1 00:50:55.471: %ALIGN-3-SPURIOUS: Spurious memory access made at 0x819F23
E0 reading 0x5B
*Mar 1 00:50:55.471: %ALIGN-3-TRACE: -Traceback= 819F23E0 81BC6550 81F132D8 819
91CFC 819923F0 819A79A4 819A7AF4 813DFBC0
*Mar 1 00:50:55.471: %ALIGN-3-TRACE: -Traceback= 819F23E4 81BC6550 81F132D8 819
Please give ur suggestion for the problem.
MAx
Max what's ur conf reg value rt now?.
how much is ur memory.Try to add one more memory if possible put some 32 mb or 64 and try .Bcoz it seems memory is not enough.ur lan connection is from E0 or E1.try connecting to E1 and try.
at first reconfigure all the interfaces after erasing nvram, and check the conf-reg value, and reload.after that you reconfigure the router and try.
Regds
Binoy.
