Bookmark
Subscribe
481
router not passing data
markm
I?m trying to connect a branch office to head office using two 1841?s across a T-1 line.
I?ve got communication between the routers across the T-1 using a static route, and from each router to the locally attached Ethernet LAN.
I do not have communication from the local LAN to any other host on the remote LAN except the router LAN port.
I?m forgetting something simple, but I?m drawing a blank. Any suggestions?
This is the relevant configuration info?.
interface FastEthernet0/0
description LAN
ip address 192.168.102.10 255.255.255.0
duplex auto
speed auto
no mop enabled
interface Serial0/0/0
description WAN
ip address 192.168.200.11 255.255.255.0
service-module t1 remote-alarm-enable
router rip
network 192.168.102.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 192.168.200.10 permanent
vladrac-ccna
Level 5
Level 5
does the remote router have route to 192.168.102/24?
vlad
Yes via the serial interfact to 192.168.200.11 (the serial port on the local router.
I've since enabled RIP on all interfaces on both routers and am still getting thre same problem.
Mark
The obvious problem in the first post was that RIP was enabled on the FastEthernet but not on the Serial. If you have fixed that and are still having a problem then I believe that the next thing to check is whether the end stations on the LAN have the correct default gateway configured.
Could you post the output of show ip route from both routers to verify that both LANs are showing up in both routing tables?
Rick
Rick
