Router performance with encryption
jacinto1m
I was wondering what is the router performance decrease when using encryption?
For instance the CISCO2911 has 180.73Mbps half duplex switching performance, what would be more or less the decrease in performance if I use encrypcion?
Thanks in advance.
Leo Laohoo
The value of "180.73" Mbps is expressed in HALF duplex and without any encryption.
The simplest rule-of-thumb is to cut the figure in half to get the value in EITHER full duplex or with encryption.  180.73 x 0.5 = 90.365.
If you want to get the value in full duplex AND with encryption then you take the value of "180.73" and factor that by four.  180.73 * 0.25 =  45.1825
So a 2911 can run up to 45.1825 Mbps in full duplex and will encryption.
NOTE:  Cisco staff might correct me on this as the VPN engine might be able to push more bandwidth than 50% but I (and some others) use the 50% rule-of-thumb widely.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
That attached documents some encryption performance for later routers.
