Join Customer Connection to register!
534
telsi
Beginner
Router: PPTP passthrough stops working
Hi folks,
it drives me crazy for a while. I spent a lot of time getting it solved, but I need your help.
I have a router connected to internet and some clients and a server behind.
The clients access internet using the natted router ip. There are some pptp clients connecting pptps servers on outside.
Local lan = 10.1.1.0/24
Server IP = 10.1.1.2
Ports pptp, https, smtp and rdp are natted from outside to private ip inside lan.
Where https and pptp can be accessed from all, smtp and rdp are just allowed for some speicific ips.
There is a ipsec tunnel to a static peer address.
Everything is working fine, but pptp.
When trying to reach server via https from outside, it is working. When trying pptp it is not.
What is the problem, how can I find out what makes packets drop?
Do I need a gre rule?
The fw and access config:
ip port-map user-protocol-rdp port tcp 3389
class-map type inspect match-all sdm-nat-smtp-1
match protocol smtp
match access-group 103
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any CCP_PPTP
match class-map SDM_GRE
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_VPN_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
class-map type inspect match-all SDM_VPN_PT
match access-group 105
match class-map SDM_VPN_TRAFFIC
class-map type inspect match-any ccp-cls-insp-traffic
match protocol pptp
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any sdm-nat-pptp-1
match access-group 101
match protocol pptp
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all sdm-nat-https-1
class-map type inspect match-all sdm-nat-user-protocol-rdp-1
match protocol user-protocol-rdp
match access-group 104
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class type inspect SDM_VPN_PT
  pass
class class-default
  drop
policy-map type inspect ccp-pol-outToIn
class type inspect sdm-nat-pptp-1
  inspect
class type inspect CCP_PPTP
  pass
class type inspect sdm-nat-https-1
  inspect
class type inspect sdm-nat-smtp-1
  inspect
class type inspect sdm-nat-user-protocol-rdp-1
  inspect
class class-default
  drop log
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-zone-To-in-zone source out-zone destination in-zone
service-policy type inspect ccp-pol-outToIn
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 10.1.1.2
access-list 102 remark CCP_ACL Category=2
access-list 102 remark tunnel net2 webserver
access-list 102 deny   ip 10.1.1.0 0.0.0.255 10.1.3.0 0.0.0.255
access-list 102 remark tunnel net1 webserver
access-list 102 deny   ip 10.1.1.0 0.0.0.255 10.1.2.0 0.0.0.255
access-list 102 permit ip 10.1.1.0 0.0.0.255 any
access-list 103 permit ip object-group SMTP_IN host 10.1.1.2
access-list 104 permit ip object-group RDP_IN host 10.1.1.2
access-list 105 remark CCP_ACL Category=144
access-list 105 permit ip host 123.123.123.123 any
TELSi
0 REPLIES 0
