Router's serial link having input errors.
supa4
Hi Wondering if anyone can help answer this problem, as my 1700 router's serial link is having constant input errors, every other minutes.
I have checked my modem which is working fine, changed a serial card. But the problem still persist. here is the "show int"
Serial0 is up, line protocol is up
Hardware is PowerQUICC Serial
Description: 2Mbps leased circuit to iASPire (Secondary)
Internet address is 198.1.254.6/30
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
reliability 255/255, txload 18/255, rxload 73/255
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:02, output 00:00:00, output hang never
Last clearing of "show interface" counters 3d06h
Queueing strategy: fifo
Output queue 0/40, 12617 drops; input queue 0/75, 0 drops
5 minute input rate 590000 bits/sec, 147 packets/sec
5 minute output rate 145000 bits/sec, 175 packets/sec
13727437 packets input, 3822921772 bytes, 0 no buffer
Received 32759 broadcasts, 0 runts, 0 giants, 0 throttles
20856 input errors, 525 CRC, 20206 frame, 0 overrun, 0 ignored, 125 abort
15015361 packets output, 3328324547 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Amtek_Secondary#
Wondering if anyone can advice?
Thanks and regards
Kum Fatt
andrewsdavid
Hi ,
As per my point of vivew, I notice onething that CRC error, there my problem with line. so first give loop on modem towards router and check whether CRC error is incrasing if it incrase then problem should be on modem or V.35 cable. If it is ok then there will be problem at Line side,
scottmac
Level 10
Level 10
It may be the cable between the Telco interface and the router (csu/dsu).
If you are using Cat{anything} (UTP) between the NIU and the csu/dsu and it's longer than 3-4 meters (and especislly if it was a "home made" cable), then that's your most likely source.
UTP is not certified for use with T1/E1, though it it frequently used successfully for short distances. The specified cable for that kind of connection is "Premises Cable" ... which is individually shielded pair, inside a shielded sheath.
Prem cable should be good for ~655 feet.
If you want to see what it looks like, check out Anixter's website|catalog|search for "premises cable"
Good Luck
Scott
amit-singh
Level 8
Level 8
Hi Kum,
Try replacing the cable between the CSU/DSU and your router. If you still have the errors, its more likely the telco issue. As posted by the first poster, Take telco people online and do the troubleshooting. You have to do the looping thing local at your end first and then check the remote loops.I have been on call manytimes for 3-4 hrs and have that problem solved completely.
HTH, Please rate if this helps.
-amit singh
HI
Amit
Can u explain me how loop test is done.
Mahmood
