Router to router IPSEC session
santoshdpawar
Hi Techs,
I  have below network with a HQ router which builds a crypto session with  private source IP (RFC1918). The firewall in the middle (WAN and HQ  router) NAT's the crupto source.
( HQ Router) --------------------------------------------( Firewall- NAT)-----WAN---------------- Remote sites over internet
c2800nm-advsecurityk9-mz.150-1.M8.bin
Each  time the remote site changes public IP or losses connection HQ router  is not able to flush the existing/old IKE/IPSEC sessions though it forms  a new one with the new public IP. When I clear crypto session on HQ the  IKE reforms and session resumes. Is there any thing with IOS on HQ (RRI  Bug) ?
Also I have crypto isakmp nat keepalive, DPD, invalid spi-recovery options enabled.
Santosh
Have you tried changing the Iskamp/Ipsec SA lifetimes? - preferably on either end off the peer
crypto isakmp policy priority lifetime (sec)
crypto ipsec security-association lifetime (sec)
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
Thanks Paul, I will definitely try this option. I was always thinking some RRI bug (routes not clearing). Any thoughts on that.
Best regards,
Santosh
res
Paul
Kind Regards
Paul
Mitchell Dyer
Are you using a dynamic crypto map on the HQ side? Seems odd that the remote router would get a new address without tearing the tunnel down or the tunnel timing out.
You might look at changing the timeout period, as previously mentioned or look into the use of keep alives.
