Router with integrated vpn and firewall features/services
adeebtaqui
Level 4
Level 4
Greetings,
I would like to know which cisco router series isr or asr is more suitable for use at branch as router with integrated vpn and firewall
If the router is for a branch site then you'll probably be fine with an ISR router, either 1000 or 4000 series. They both support Zone-Based Firewall and IPSec VPN (crypto map, DMVPN, FlexVPN, GETVPN etc).
Datasheets for 4000 and 1000.
balaji.bandi
Depends on size of the Branch device and network .
ISR 4000 is good, we have deployed many for medium sized branch users. make sure you buy right license for througput
BB
When is ASR 1001-10G preferred
Is it mainly for core deployment at customer edge to interface with service provider ?
Regarding throughput, what is the best way to analyse how much throughput shall be appropriate for our deployment.
Is there any cisco doc explaing this.
Kindly share
here is the good reference document : ( also you need to consider Cost model)
https://www.cisco.com/c/dam/global/hr_hr/events/2016/cisco-connect/pdf/Cisco_IOS_XE_Routers_-_ASR_1000_and_ISR_4000_-_The_Evolution_of_Converged_Network_Edge_Architectures_-_Jaromir_Pila_Cisco.pdf
Model can be decide once you have future visibility, what is wan bandwidth requrirement for next 3-5years. (beauty of this is, you can start with small bandwidth with Software license you can upgrade later higher throughput with out any downtime. or reboot of the device).
BB
