router2801
this router2801 is 3 in 1? including firewall,router and switch?
Richard Burts
Michael
Potentially the answer is yes. Depending on how you order and install it you can get some or all of these features. Certainly it is a router. If you have the correct software feature set installed it can act as a firewall. And if you install one of the switch modules that it supports then it can do Ethernet switching. It is quite a versatile box.
Rick
Rick
