Routes to serial B when serial A is down...
cindylee27
Hi Experts,
I have a problem here. Ethernet A is connected to the router from firewall. the default network A is pushing to Ethernet A.
I would like to manipulate network A to push to Serial B when serial A is down.
How can I do that?
Thanks.
mounir.mohamed
Level 7
Level 7
Actually more input should be added to understand your case correctly, but backup static routes can be done by add a mirror route with higher AD pointing out the backup interface
For example.
ip route 0.0.0.0 0.0.0.0 serial0
ip route 0.0.0.0 0.0.0.0 serial 1 253
Best Regards,
Mounir Mohamed
