routing C8200L-1N-4T
harishnimje
we need to know C8200L-1N-4T having EAL2+ Certificate if yes then please share the link
M02@rt37
Hello @harishnimje
-- https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8200-series-edge-platforms/catalyst-8200-series-edge-platforms-faq.html
There is no more public info ... no more confirming an EAL2+ cert for this model!
Check here please: https://www.commoncriteriaportal.org/products/index.cfm
-- per contructor/per model
Best regards
balaji.bandi
May be worth contacting TAC or support or sales for this kind of certificate.
BB
Jens Albrecht
Hello @harishnimje,
regarding such certifications you can take a look at the Common Criteria Portal and filter based on the vendor and compliance you are looking for:
As you can see, the certification was issued in this case not for a specific platform but based on the specific role and software versions. If you meet the outlined use case and firmware, then the answer is yes.
HTH!
