Routing issue
nawate77
hi guys my first post, kindly please tell me whats wrong with my configs that i cannot connect to the internet
ip dhcp relay information trust-all
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.11.1 192.168.11.10
ip dhcp pool xxxx
network 192.168.11.0 255.255.255.0
default-router 192.168.11.1
dns-server x.x.208.19 x.x.208.18
ip dhcp global-options
dns-server 41.203.208.19 41.203.208.18
ip name-server 192.168.11.1
ip name-server 197.x.x.2
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server x.x.208.19
ip name-server x.x.208.18
ip cef
no ipv6 cef
interface FastEthernet0
switchport access vlan 50
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address x.x.x.2 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
description $ETH_LAN$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
interface Vlan50
ip address 192.168.11.1 255.255.255.0
ip nat inside
interface Dialer1
no ip address
no cdp enable
ip default-gateway 197.248.111.1
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication aaa
ip http secure-server
ip http secure-trustpoint netCA
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip dns spoofing 192.168.11.1
ip nat inside source list NAT_INSIDE interface FastEthernet4 overload
ip default-network x.x.111.0
ip route 0.0.0.0 0.0.0.0 x.x.111.1
ip access-list standard NAT_INSIDE
permit 192.168.11.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
Giuseppe Larosa
Hello Nawate77,
at first glance the configuration looks like correct but allows access to the Internet only to users in Vlan 50 and not to users in Vlan 1.
If you have the ip routing enabled the ip default-gateway command is not needed.
It is really important that your default static route ip route 0.0.0.0 0.0.0.0 uses an IP next-hop that is reached out of Fas4 the outside interface.
NAT is only triggered when traffic is received on inside interface and has to be sent out an NAT outside interface.
To verify if you have a working internet connection from the router shell you can try to ping 8.8.8.8.
If this works you can move to use an extended ping and specify a source IP address of Vlan 50 on the router.
Also you may want to configure the ip tcp mss-adjust 1452  also under Vlan 50 to avoid issues with MTU if you are using a PPPoE internet access. I think this is needed. In alternative configure ip mtu 1492 on Fas4 and under Vlan50 SVI.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Nawate77,
Hope to help
Giuseppe
jurczak
try moving the settings from FA4 to VLAN1 and remove the ip default-network from the global config.
no ip address
interface Vlan1
ip nat outside
ip nat inside source list NAT_INSIDE interface Vlan1 overload
In any case I think that it would be better to use vlan50 or any other vlan as WAN interface
on a side note, looking at your config, the fact that you have an entire class C network available for your outside interface seems odd. Typically, the mask would be 255.255.255.252. and then you would use 197.248.111.1 as the next hop, and 197.248.111.2 for the FastEthernet4 address. So try and change the mask as below (marked in bold):
ip address 197.248.111.2 255.255.255.252
ip nat outside
duplex auto
speed auto
the masking of 255.255.255.252 on the required mask, thanks for that
also I had to do port-tagging on fa4 to the ISP vlan.
