Routing Issue
Visauk47
Hi Guys,
I am not able to communicate from PC1 to PC2 on a Routed network, Topology attached.
PC1 is on VLAN21 and PC2 is on VLAN22 , both ports are configured as access ports and allowed VLAN 21 and 22
Could someone please check and update where is the config error ?
Pbx1 switch Config
hostname pbx1
boot-start-marker
boot-end-marker
ip routing
ip domain-name Test
vtp domain pbx1
vtp mode transparent
spanning-tree vlan 10 priority 4096
auto qos srnd4
vlan internal allocation policy ascending
vlan 10
name PC
vlan 21
name Server
interface Loopback0
ip address 172.16.0.1 255.255.255.255
interface GigabitEthernet0/9
description *** PC-1 ***
switchport access vlan 21
switchport mode access
spanning-tree portfast edge
interface GigabitEthernet0/15
description *** Routed link to es1 ***
no switchport
ip address 172.16.10.1 255.255.255.252
interface GigabitEthernet0/16
description *** Trunk link to Ip1 G0/15 ***
no switchport
ip address 172.16.10.10 255.255.255.252
interface Vlan1
no ip address
shutdown
interface Vlan10
description **** Management IP Address ****
ip address 172.16.1.222 255.255.255.0
interface Vlan21
ip address 172.21.20.222 255.255.255.0
router eigrp 10
network 172.16.0.0
network 172.21.0.0
eigrp stub connected summary
ip forward-protocol nd
ip http server
ip http secure-server
snmp-server community Test
snmp-server location pbx1
snmp-server contact Testing
end
ES1 switch Config
hostname es1
ip routing
ip domain-name Test
vtp domain es1
spanning-tree vlan 20 priority 4096
vlan 20
name PC
vlan 22
name Servers
interface Loopback0
ip address 172.16.0.2 255.255.255.0
interface GigabitEthernet0/10
switchport access vlan 22
description *** Routed link to pbx1 G0/15 ***
no switchport
ip address 172.16.10.2 255.255.255.252
description *** Routed link to Ip1 G0/16 ***
no switchport
ip address 172.16.10.5 255.255.255.252
interface Vlan1
no ip address
shutdown
interface Vlan20
ip address 172.16.2.222 255.255.255.0
interface Vlan22
ip address 172.21.0.222 255.255.255.0
router eigrp 10
network 172.16.0.0
network 172.21.0.0
eigrp stub connected static
ip http server
snmp-server location es1
end
VS
Hi @Visauk47 ,
Just make sure that PC2 is configured with an IP address that falls within the subnet configured for VLAN22 (172.21.0.0/24) then.
For instance:
PC2 IP address 172.21.0.35/24
Default gateway: 172.21.0.222
5 Replies 5
Harold Ritter
Hi @Visauk47 ,
You need to add network 172.16.10.0 on both routers to activate EIGRP on the link between the two routers.
router eigrp 10
network 172.16.10.0
Also, according to your diagram PC2 address does match the subnet you configured for VLAN22 (172.21.0.0/24). Make sure to configure PC2 accordingly.
Hi Harold,
Router Eigrp 10
Network 172.16.0.0 is already activated on the link
Do I have to create a new VLAN21 on ES switch ?
Vs
Hi @Visauk47 ,
For instance:
Hi Harold,
Thanks, that's what I have done now to make to work
VS
please try eigrp no auto summary in each router because you use same parent prefix.
