Routing Performance
scollins34
I have a customer using a 100 Mbps Ethernet circuit and I need a router that can handle that type of throughput. Is it possible to give me the algorithm you guys use to figure this out with concurrent services of Voice, NAT, Encryption?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Unsure you'll find an algorithm, as performance for different services depends much on platform and IOS version.  Usually, best you can do is go by performance fact sheets provided by vendor.  For the later ISRs, Cisco has a nice performance whitepaper (which I've attached a copy).
