Routing Problem
rajib_das
We have BGP connection with Two Diff ISPs(say A and B) with different Bandwith.
The problem that I m facing is that when i traceroute my network from outside network , I can see only the traffic is coming through only particular ISP (say A) consequently the Ineternet browsing is going slow.
Pls guide how i can divert the incoming traffic into network through ISP "B" by defualt.
pls help me.
Richard Burts
Rajib
The mechanism that you would use to divert incoming traffic to ISP B would be to prepend your AS number in the advertisements that you send to ISP A. You would et up a route map that will process updates sent to ISP A and in the route map you will specify that your AS number is prepended. The result of this is that your AS is preferred through ISP B.
Rick
Rick
thanks rick
