Routing Protocol
Joe Lee
Hello Everyone,
One of my clients has router connected to the MPLS via eBGP, and all switches/LAN's use EIGRP. On the router, they redistributed EIGRP over the BGP so all the site can communicate each other. They are thinking to change the protocol EIGRP in the LAN, Which is better solution, OSPF or iBGP to run on the switches/LAN? Please advise.
Joe
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
As iBGP normally runs across an IGP, and it generally converges slower, don't see many advantages using it alone.  Even with an IGP, unless you have multiple eBGP routers, i.e. you want them to talk BGP between them on the LAN side, don't see many advantages for that either.
As to replacing EIGRP with OSPF, both very much alike in their major features to support most IGP needs.  Perhaps biggest difference EIGRP does have some advantages over OSPF, OSPF is supported on non-Cisco.
