Routing Question
oneirishpollack
I am working in Netsim, and have 4 routers. I am trying to get RIP working.
Router 1= corp router = s0/0 10.1.1.1, s0/1 10.1.2.1, s0/2 10.1.3.1
Router 2= branch router s0/0 10.1.1.2, e1/0 10.1.5.1, e1/1 10.1.6.1
Router 3= branch router s0/0 10.1.2.2, e1/0 10.1.7.1, e1/1 10.1.8.1
Router 4= branch router s0/0 10.1.3.2
I used the following commands on all routers:
rip router
network 10.0.0.0
When I do a sh ip route...no rip routes.
Below are two excerpts:
Corp router:
interface Serial0/0
ip address 10.1.1.1 255.255.255.0
no ip directed-broadcast
clock rate 64000
interface Serial0/1
ip address 10.1.2.1 255.255.255.0
clock rate 64000
router rip
network 10.0.0.0
Gateway of last resort is not set
10.0.0.0/24 is subnetted, 4 subnets
C 10.1.1.0 is directly connected, Serial0/0
C 10.1.4.0 is directly connected, Serial0/3
C 10.1.2.0 is directly connected, Serial0/1
C 10.1.3.0 is directly connected, Serial0/2
Branch router1:
interface Serial0/0
ip address 10.1.1.2 255.255.255.0
interface Ethernet1/0
ip address 10.1.5.1 255.255.255.0
interface Ethernet1/1
ip address 10.1.6.1 255.255.255.0
router rip
network 10.0.0.0
C 10.1.5.0 is directly connected, Ethernet1/0
C 10.1.6.0 is directly connected, Ethernet1/1
C 10.1.4.0 is directly connected, Serial0/1
13 Replies 13
Edison Ortiz
You are experiencing the split-horizon rule.
All the subnets you mentioned are the same in their classful nature so the router won't accept advertisement it already knows about.
If you can fix this problem by going with version 2 under RIP and enable no auto-summary
__
Edison.
CriscoSystems
Level 5
Level 5
You need to configure "version 2" in router configuration mode.
RIP version 1 doesn't support variable-length subnet masking. The RIP process on each of your routers is therefore only reporting network 10.0.0.0. Since each router already has this network, with a)longer masks/prefixes and b)lower administrative distance (directly connected vs RIP); they won't place any of RIP's info into their routing tables.
Set each one up for RIPv2 and you should be in better shape.
(please remember to rate helpful posts)
Edison
I do not see how you analyze this as a split horizon issue. In the original post it is pretty clear that the Branch router is connected via its serial to the Corp router. And the Branch router has 2 subnets on its Ethernet interfaces that match the RIP network statement. So how does split horizon prevent the Branch from advertising its Ethernet subnets over the serial interface?
Seth
How do you analyze this as a variable length subnet issue. In the original post it is pretty clear that all subnets are 255.255.255.0. All are the same length and not variable.
I am not clear what the problem is, but I do not believe that it is either split horizon or VLSM.
I would like to see a more complete configuration of these router to try to identify what the issue is. I would also like to see the output of show cdp neighbor detail to verify that the routers are connected as the original post suggests that they are. And the output of show ip protocol would also be helpful.
Rick
Rick
Hmmm, yes I suppose they are all 24-bit masks. I shoulda looked more closely at the configs.
But you are right, we need more info on the configs as well as on the layer 2 state of things.
Ok guys, here is the config from the Corp router and one of the branch routers. You are correct there is two subnets off the branch router (10.1.5.0/24, 10.1.6.0/24).
Please note this is in Netsim.
Corp router
corprouter#sh run
Building configuration...
Version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname corprouter
ip subnet-zero
interface Serial0/0
clock rate 64000
interface Serial0/1
clock rate 64000
interface Serial0/2
ip address 10.1.3.1 255.255.255.0
clock rate 64000
interface Serial0/3
ip address 10.1.4.1 255.255.255.0
clock rate 64000
no ip address
shutdown
no ip address
shutdown
interface Ethernet1/2
no ip address
shutdown
interface Ethernet1/3
no ip address
shutdown
router rip
network 10.0.0.0
ip classless
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
no scheduler allocate
end
BRANCH ROUTER
Router#SH RUN
Version 12.1
hostname Router
ip subnet-zero
interface Serial0/0
interface Serial0/1
ip address 10.1.4.2 255.255.255.0
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router rip
network 10.0.0.0
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
________________________________
From the Corp router I can ping:
10.1.1.2
From the branch router I can ping:
10.1.1.1
10.1.5.1
10.1.6.1
10.1.5.11 (one of the PC's)
CORP ROUTER
corprouter#SH IP ROUTE
BRANCH ROUTER
Router#sh ip route
But from the corp router you can't ping 10.1.2.1 or 10.1.3.1?
So far you've only verified layer 2 connectivity to Router 2. What about the other branch routers?
Can you give us the output of "show ip rip database" on the corp router?
Yes. I can ping all the branch routers from the corp router.
I cannot however ping any networks connected via the branch routers.
"sh ip rip database" is not available in netsim.
If I add a static route to 10.1.5.1 on the corp router. They are able to ping each other.
The configs as posted look ok and I would expect RIP to be advertising the subnets. If the route tables are not showing that I wonder if there is some aspect of netsim that we are encountering. Perhaps the output of show ip interface brief and the output of show ip protocol might shed some light on this.
Rick
Rick
Here is the output. - Thanks for your help.
Corp Router
Serial0/0 10.1.1.1 YES unset up up
Serial0/1 10.1.2.1 YES unset up up
Serial0/2 10.1.3.1 YES unset up up
Serial0/3 10.1.4.1 YES unset up up
Ethernet1/0 unassigned YES unset administratively down down
Ethernet1/1 unassigned YES unset administratively down down
Ethernet1/2 unassigned YES unset administratively down down
Ethernet1/3 unassigned YES unset administratively down down
Routing Protocol is "rip"
Sending updates every 30 seconds, next due in 28 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Outgoing update filter list for all interfaces is
Incoming update filter list for all interfaces is
Redistributing: rip
Default version control: send version 1, receive any version
Interface Send Recv Key-chain
Serial0/0 1 1 2
Serial0/1 1 1 2
Serial0/2 1 1 2
Serial0/3 1 1 2
Routing for Networks:
10.0.0.0
Routing Information Sources:
10.1.2.2 120 00:00:03
10.1.1.2 120 00:00:015
Distance: (default is 120)
Branch Router
Router#sh ip int brief
Serial0/0 10.1.2.2 YES unset up up
Serial0/1 unassigned YES unset administratively down down
Serial0/2 unassigned YES unset administratively down down
Serial0/3 unassigned YES unset administratively down down
Ethernet1/0 10.1.7.1 YES unset up up
Ethernet1/1 10.1.8.1 YES unset up up
Router#sh ip protocol
Sending updates every 30 seconds, next due in 29 seconds
Redistributing: rip
Serial0/0 1 1 2
Ethernet1/0 1 1 2
Ethernet1/1 1 1 2
10.0.0.0
10.1.2.1 120 00:00:06
could you try to issue the no auto-summary command under the rip process on each router?
router(config)#router rip
router(config-router)#no auto-summary
by default, rip will summarize networks to its classful boundary. in your config, the 10.0.0.0 network would be advertised using a subnet mask of 255.0.0.0. this goes against your config on each router interface which has a subnet mask of 255.255.255.0. give it a try.
John, I also thought that was the problem, till rburts pointed out that all routers have the same subnet mask. RIPv1 effectively supports a non-classful mask as long as the mask is the same length on all interfaces.
I recreated the op's issue in my lab, with actual 2500 routers, and the 24-bit Ethernet subnets (loopbacks in my lab) were reported to a RIP neighbor, over a separate point-to-point link, just fine. I confirmed both routers were running RIP verion 1.
So it really does look more like a netsim issue than a configuration one.
Thanks for the additional information. I do not see anything in it that really points to what the problem is. I do see something that I believe is significant. From the output of show ip protocol from the Corp router:
This indicates that it has received a RIP update from the branch router at 10.1.1.2. If it has received a RIP update then why are there no RIP routes in its routing table?
I do note that the branch router does not report receiving a RIP update from the Corp router.
I am not familiar with netsim and how it deals with certain aspects of routing but I am coming to feel that we are dealing with some problem in netsim rather than a problem with the config.
Rick
Rick
Thanks for verifying that. I didn't see anything wrong based on my limited knowledge, but wanted to double-check with some of you pros.
This site is just incredible.
Thanks again for all of your time and effort.
K
