Routing Table Entries support on Cisco 1921/K9
rahulja
Hello
Is there a Table which the list the route table entries on Cisco ISR Router especially ISR 1921 Router.
regards
Rahul
shivjain
hi
show ip route command will give you the list of all the routes installed in routing table.
regards
shivlu jain
www.mplsvpn.info
Hello Shiv
I want to place Cisco 1921 towards the Internet. What is the size of the BGP Table or the Number of BGP Routes Cisco 1921 can support?
I am sizing the Router and will have a approx 10 Mbps internet link connected to the Router.
thanks
Hi Rahul
Those are software-forwarding platforms and the BGP routes capacity will depend on the amount of RAM installed. IOS along with specific version/feature set will eat some of it, so it's usually answered by "it depends".
Currently there are 435000 BGP routes are available and I would recommend you not to accept the full routing table. on 1941 better to configure a one static default route pointing towards your ISP.
regards
shivlu jain
