Routing VLAN to internet
Hi, i need route from VLAN to internet. I cannot ping from any VLAN to internet. I tried do Router On Stick, but ping from vlan to internet doesnt working.
Here is a running-config on Router and topology. Thank for help
Router running-confi
  Topology
 Addressing
6 Replies 6
Hello
Can you post the PT file
Kind Regards
Paul
Can u open it ?
sfriday02
In general unless your carrier runs a dynamic routing protocol with you(which they probably wont unless you pay for it) - ATT/VZ support BGP/EIGRP for customer interfaces.... and will send your router a default route... which makes your life easy.... otherwise you need to know what the upstream interface is... or force all traffic out your carrier interface and build a static default route as follows:
ip route 0.0.0.0 0.0.0.0 [upstreamipfromyourcarrier]/[OR/Directly attached interface]
ip route 0.0.0.0 0.0.0.0 g0/0
to do that you simply have to config t....
to verify show ip route [you should see the static default route in your RIB]
looking at your configs however you dont have an ip address on your vlan, and its shut.
config t
vlan1
ip address X
no shut
All directly attached interfaces will be in the RIB regardless of any dynamic protocols you are running... and you dont have an IP on the other GIGE interface either...
