Routing with different protocols
IT Anil Sikar
There are three possible routes for a router to reach a
destination network. The first route is from OSPF with a metric
of 782. The second route is from RIPv2 with a metric of 4. The
third is from EIGRP with a composite metric of 20514560.
Which route will be installed by the router in its routing table?
@cisco
3 Accepted Solutions
Harold Ritter
Hi @IT Anil Sikar ,
The lowest administrative distance will be used to installed the route in the routing table. The above mentioned routing protocols have the following administrative distances: EIGRP (90), OSPF (110) and RIP (120).
The EIGRP route will therefore be installed in the routing table.
BTW, the AD values @Harold Ritter mentions are the defaults, which can be changed.
The rule is
The lowest AD
If ad same then tiebreak will be metric
If metric same then router will use ECMP
MHM
7 Replies 7
Harold Ritter
Hi @IT Anil Sikar ,
The rule is
The lowest AD
MHM
"If ad same then tiebreak will be metric
If metric same then router will use ECMP"
Hmm, recall a prior question about what happens when different routing protocols are used when they have same (non-default) AD.  I vaguely recall (???) tie breaking was not done by a route's internal metric but by default AD values.
For example if I have an EIGRP and an OSPF route each with an AD of 100, EIGRP route would be used.
IT Anil Sikar
You are so welcome
MHM
you are very welcome @IT Anil Sikar and thanks for the feedback
