Routing
calebstepp25
Can anyone give me the configuration for this lab trying it at home on what the whole confit would be?
6 Replies 6
 Which devices do you have? I mean, model and version?
No version or model type just a home lab with the two switches and 1 router
Just what would the config be for Router1. Switch 1 and switch 2
The config may vary depending on the device model and version
 It is a lot of config so,  give this information and I help you.
Both switches are Cisco catalyst 9400 series and the router is a Cisco 7200
series
Start by adding IP address on each interface. If you did not yet.
If you did, put the interface between switches  in trunk
Int giga/fast x/x
 Switchport trunk
For router, you can configure the ospf with
router ospf 100
 Network x.x.x.x x.x.x.x area 0
Do it and let me know.
