I have MVPN service in MPLS network.
I recently connected new source of multicast into my CORE router which I also do an RP-candidate for groups of this source.
In my network I also have two other RPs with others groups on others routers .
The CORE router also is BSR candidate and it successfully mapped this two RPs, but it mapping for own RP does not work.
If i move BSR candidate on another router, which is not RP then all three RPs are mapped successfully.
IS it possible to have RP and BSR candidate in the same router?
IMHO in a global RP configuration all work fine. This issue observed only in vrf configuration.
ip pim vrf IPTV rp-candidate Port-channel1.329 group-list 99 interval 15
ip pim vrf IPTV bsr-candidate Port-channel1.328 0
Interface Po1.328 — receivers of multicast from RP[1-3] on the CORE router
Interface Po1.329 — source of multicast for RP on core router.
candidate bsr and RP will work in the same box,
But in fact they does not work.
Some more config on CORE router
ip multicast-routing
ip multicast-routing vrf IPTV
mls ip multicast replication-mode ingress
mls rate-limit multicast ipv4 fib-miss 1000 100
ip pim rp-candidate Loopback0 interval 15
no ip pim v1-rp-reachability
ip pim bsr-candidate Loopback0 0 3
interface Port-channel1.328
description ---# VLAN to METRO:iptv [S0]
encapsulation dot1Q 328
ip vrf forwarding IPTV
ip address 10.61.240.9 255.255.255.248
ip pim neighbor-filter 97
ip pim dr-priority 2
ip pim query-interval 15
ip pim sparse-mode
ip igmp last-member-query-interval 100
interface Port-channel1.329
description ---# VLAN to IPTV:uplink [S2]
encapsulation dot1Q 329
ip address 192.168.253.54 255.255.255.252
ip access-group iptv:uplink in
ip access-group 100 out
no ip proxy-arp
ip pim query-interval 120
ip pim bsr-border
ip pim dense-mode
ip igmp unidirectional-link
access-list 97 deny 10.61.240.0 0.0.3.255
access-list 97 deny 192.168.253.52 0.0.0.3
access-list 99 permit 239.32.4.0 0.0.0.255
access-list 99 deny any
access-list 100 deny ip any 224.0.0.0 15.255.255.255
ip access-list extended iptv:uplink
permit ip host xx.xx.xx.248 239.32.4.0 0.0.0.255 // where xx.xx.xx.248 is a public address of source
permit ip any any
ip route vrf IPTV xx.xx.xx.248 255.255.255.255 192.168.253.53
router ospf as-num
mpls traffic-eng multicast-intact
IF the BSR is a remote router all looks magnificently
#sh ip pim vrf IPTV bsr-router
PIMv2 Bootstrap information
BSR address: 10.61.240.33 (?)
Uptime: 09:11:28, BSR Priority: 1, Hash mask length: 0
Expires: 00:01:43
This system is a candidate BSR
Candidate BSR address: 10.61.240.9, priority: 0, hash mask length: 0
Candidate RP: 192.168.253.54(Port-channel1.329),
#sh ip pim vrf IPTV rp mapping
PIM Group-to-RP Mappings
This system is a candidate RP (v2)
Group(s) 239.1.0.0/24
RP 10.61.243.14 (?), v2
Info source: 10.61.240.33 (?), via bootstrap, priority 0, holdtime 150
Uptime: 12:25:21, expires: 00:01:48
Group(s) 239.1.1.0/24
RP 10.61.241.1 (?), v2
Uptime: 12:25:28, expires: 00:01:51
Group(s) 239.1.2.0/24
Uptime: 12:25:28, expires: 00:01:48
Group(s) 239.32.4.0/24
RP 192.168.253.54 (?), v2
IF i do this system as BSR then RP mapping for 192.168.253.54 disappear
This system is the Bootstrap Router (BSR)
BSR address: 10.61.240.9 (?)
Uptime: 00:00:03, BSR Priority: 2, Hash mask length: 0
Next bootstrap message in 00:00:56
This system is the Bootstrap Router (v2)
Info source: 10.61.243.14 (?), via bootstrap, priority 0, holdtime 37
Uptime: 12:35:55, expires: 00:00:23
Info source: 10.61.241.1 (?), via bootstrap, priority 0, holdtime 37
Uptime: 12:36:02, expires: 00:00:22
