I'm using a few ASR9006's running IOS XR Version 5.3.1, and I'm trying to get RPKI Validation working for neighbors inside a VRF:
My config looks something like this:
router bgp ASN
nsr
bgp router-id x.x.x.x
rpki server y.y.y.y
transport tcp port 8282
refresh-time 600
bgp bestpath origin-as use validity
bgp bestpath origin-as allow invalid
vrf VRF
rd x.x.x:100
neighbor x.x.x.x
remote-as xxxx
address-family ipv4 unicast
route-policy rpki-test in
The RPKI Validation server is up and caching ROAs:
RP/0/RSP1/CPU0:router#show bgp rpki server summary
Thu Aug 27 09:57:56.875 CET
Hostname/Address Transport State Time ROAs (IPv4/IPv6)
x.x.x.x TCP:8282 ESTAB 18:55:02 14413/2123
However I cannot see any RPKI Validation states on the prefix I receive from peers:
RP/0/RSP1/CPU0:router#show bgp vrf VRF ipv4 unicast x.x.x.x/x
Thu Aug 27 09:59:53.474 CET
BGP routing table entry for x.x.x.x/x, Route Distinguisher: x.x.x.x:100
Versions:
Process bRIB/RIB SendTblVer
Speaker 1612 1612
Local Label: 289992
Last Modified: Aug 26 16:24:06.528 for 17:35:46
Paths: (2 available, best #2)
Advertised to PE peers (in unique update groups):
x.x.x.x
Path #1: Received by speaker 0
Not advertised to any peer
XXX
x.x.x.x from x.x.x.x (x.x.x.x)
Origin IGP, metric 18, localpref 140, valid, external
Received Path ID 0, Local Path ID 0, version 0
Community: 64999:4 64999:140
Extended community: RT:XXXX:100
Path #2: Received by speaker 0
x.x.x.x
XXXX
Origin IGP, metric 17, localpref 140, valid, external, best, group-best, import-candidate
Received Path ID 0, Local Path ID 1, version 1612
But for peers in default-vrf it works fine:
RP/0/RSP1/CPU0:router#show bgp ipv4 unicast 172.16.0.0/24
Thu Aug 27 09:46:54.486 CET
BGP routing table entry for 172.16.0.0/24
Versions:
Speaker 85 85
Last Modified: Aug 27 09:46:42.521 for 00:00:12
Paths: (1 available, best #1)
Advertised to peers (in unique update groups):
x.x.x.x
x.x.x.x
65000
10.20.201.170 from 10.20.201.170 (10.20.201.170)
Origin IGP, localpref 100, valid, external, best, group-best, import-candidate
Received Path ID 0, Local Path ID 1, version 85
Origin-AS validity: not-found <<<<<<<<<<<<<<<<<<<<< Validation not-found, as expected
Am I missing something or is this just not supported?
