Routing
Don't miss this Cisco Catalyst 8000 offer
Labels
Finding accurate answers to your questions and issues is always gratifying, but what if these answers are shared globally across different languages? The Cisco Community team has been working on a proof of concept (PoC) to take Accepted Solutions in...
Kelli Glass by Community Manager
  • 10273 Views
  • 7 replies
  • 16 Helpful votes
Hi, we have a WAN and VSAT connection to one of the site. WAN is primary and VSAT is secondary link.We have dedicated router for WAN and VSAT. VSAT link is connected to one of the LAN access switch.Could you please help me, what kind of configuration...
inhamit by Level 1
  • 190 Views
  • 6 replies
Can someone tell me how do I do routing here ? it does not matter if it is static or dynamic I just want to ping same vlans and also I dont want to have different vlans to be pinged
Hi All,I have 2 networks connected via OSPF. I need to route the connected networks to a third network via BGP.I noticed that BGP peering is established but no entry is visible on the routing table.Below is an extract of BGP config:router bgp 65200.1...
Ranjita by Level 1
  • 217 Views
  • 11 replies
Hi, how are you :). I have one question, about router  Cisco 2911, and Juniper Netscreen 25, ver 5.4. I must start IP Sec tunnel between these two devices. I must use agressive mode, I saw this in configuration document. Question, how can I use agres...
I have simple nat config which I need to use:ip nat pool test 40.0.0.3 40.0.0.3 netmask 255.255.255.0ip nat inside source list 1 interface GigabitEthernet0/0/1 overloadip nat inside source list 2 pool test overloadaccess-list 1 permit 10.0.0.0 0.0.25...
Vyncy by Level 1
  • 67 Views
  • 0 replies
The host for my current server (Windows Hyper-V machine with four or five VMs) that handles my email and web sites is going away. I'm planning on moving that physical server to my house and using DDNS to route that traffic in. Realize this is very lo...
Hi Experts,Basic question regarding the ISIS process. If I have a default config of ISIS between simple two IOS-XR routers:In this case both level-1-2 will form neighbor relationship.RP/0/RP0/CPU0:test1#sh run router isisrouter isis ISIS-COREnet 49.0...
So I've been working on my project and I've implemented vlans nad also router stick.Now I want to block connections between vlans that are not same with extended access list but something does not work..Here are the commands that I've writtenip acces...
