RV320/RV325 Firmware Rev 1.4.2.22_20190402 causing WAN lockup
Chappo64
Beginner
Beginner
First time user of this forum, hope this is the right spot for this one.
I have 2 x RV-320 and 2 x RV-325 Routers that are connected by Gateway to Gateway IPSec VPN's. Each also has a client to gateway IPSec VPN and a Easy VPN to allow iPad access.
Since upgrading to the latest v1.4.2.22_20190402 firmware about 2 weeks ago, I have had to power cycle each unit multiple times due to the WAN port locking up and dropping the VPN's.
Under these circumstances, I can't access the router web page through either the LAN ports or remotely via the WAN. The only solution is to power cycle the router.
Traffic is still passing between the LAN ports and each site is operating as an isolated network.
I can ping devices from with-in each network, but cannot ping the router itself.
I've had to roll back to the previous firmware to stabilise each router.
Has anyone else experienced any issues with this firmware update?
Is there something in the update that changes the config that could cause this issue?
Thanks in advance.
0 Replies 0
Recognize Your Peers
