Routing
Don't miss this Cisco Catalyst 8000 offer
Labels
Finding accurate answers to your questions and issues is always gratifying, but what if these answers are shared globally across different languages? The Cisco Community team has been working on a proof of concept (PoC) to take Accepted Solutions in...
Kelli Glass by Community Manager
  • 10028 Views
  • 7 replies
  • 16 Helpful votes
1. Make end to end connectivity first. 2. Block the network for these site   1)Make sure that Site 4 will not advirtise any network to Site 5 which it receiving from Site3 routers.  2) On site 5 , when we check routing table of R2 router,  it dont ha...
Hi, im having issues pining between devices, i also cannot figure out how to connect the D1 switch and R1 router. Password for secret is class and normal password is cisco. Would appreciate any help or guidance! thank you !!
jushb001 by Level 1
  • 87 Views
  • 1 replies
Assume that there are three router type devices outside firewall, and one core switch router behind one layer firewalland I would like to hide the router hop of core switch router from traceroute how to modify TTL to less values at router at the most...
Maivakov by Level 1
  • 128 Views
  • 4 replies
        VRF Route LeakAs already we know that, Virtual Routing and Forwarding (VRF) is a technology for creating separate virtual routers on a single physical router. Ro...
Gopinath_Pigili_0-1711683498667.png Gopinath_Pigili_2-1711683525711.png Gopinath_Pigili_3-1711683877641.png Gopinath_Pigili_4-1711683925500.png
Assume I have to routing among different block of campus network with a square cross connected with OSPF peer to peer type,what is the disadvantage of this square cross design?Is ACI fabric used to replace this square cross design? or replace campus ...
Maivakov by Level 1
  • 97 Views
  • 1 replies
I have recently taken over a site that utilizes a Cisco Router to act as their public facing device/firewall. I have been tasked with setting up a IKEv2 S2S tunnel with one of our external vendors, and it will need to be setup on this router.I have w...
IWSup by Level 1
  • 264 Views
  • 12 replies
I'm having a bit of a bother with my attempts to install and run Cisco Configuration Professional software.  From the cisco support website, the install instructions indicate a link to download the software for CCP.  -> http://www.cisco.com/en/US/doc...
Greeting everyone! There is a little problem with configuring tacacs server on ws-2950-24 model switch. The rest switches we have are 2960 series, also 3xxx series and others, more modern versions. We always configured tacacs server this way:tacacs-s...
Hello Team,I'm facing a challenge to apply a patch on the Cisco ISR4331. See the below error message from the router. SIMBA-RT#install add file bootflash:isr4300_cpld_update_v2.0.SPA.bin activate commitinstall_add_activate_commit: START Wed Mar 27 11...
dissai by Level 1
  • 158 Views
  • 6 replies
Hello,I have very simple Cisco EVPN VxLAN fabric running on Cisco nexus 93180YC-EX switches. I am using OSFP + iBGP for underlay/overlay with Multicast. I have border-leaf switches connected to single ISP with eBGP peers and I am advertising my publi...
these routers are direclty connected via point to point connection.  When I try summarization, only ip route x.x.x.x x.x.x.x null0 with network statement works for me.  When I use the aggregate address command I dont see summary route in route table....
davinci by Level 1
  • 3782 Views
  • 6 replies
                                                         VRF LITEVRF Lite is a simplified version of VRF that uses only IP routing, while the full version of VRF can support multiple routing protocols like OSPF and BGP.VRFs are an essential component...
Gopinath_Pigili_0-1711559660914.png Gopinath_Pigili_1-1711560342503.png Gopinath_Pigili_5-1711561314609.png Gopinath_Pigili_4-1711561261838.png
