Join Customer Connection to register!
131
Phuong Trinh
Beginner
S2960 ports problem to issue the IP Address
I have a stack 24 ports and 48 ports using the stackable module. The stack is configured to do the DHCP Server Port-Based Address Allocation which will assign a fix address to each port. I have problem right now is could not get the ip address from port 12 and 14 same on both switches. I also have and another stack that build with the sam confgiuration and has the same problem: port 12 and 14 on both switches could not get the ip address. Any idea that what causing this problem. Attached is my config file and here is the version:
Switch# show version
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 28-Jan-13 10:28 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWARE (fc1)
Switch uptime is 16 hours, 13 minutes
System image file is "flash:/c2960s-universalk9-mz.122-55.SE7/c2960s-universalk9-mz.122-55.SE7.bin"
0 REPLIES 0
